Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Motorguide brute 567, 67 lb. thrust
I have a hand operated trolling motor. When i turn the handle to go forward, the motor will not engage and it will not move forward. When I turn to reverse, it engages and moves backward. What is the problem?
Can you help me?
Tony Castillo, My email tcbc.castillo@sbcglobal.net
  • 8774bc Sep 29, 2008
    yes, it is twist handle. thanks
  • Anonymous Mar 24, 2014
    I have a Motorguide T52 Trolling motor and is only working in reverse and where can i purchase a Motorguide T52 Rotary switch in the UK please
    President:
  • 1,450 Answers
You will probably find it is either a switch problem or your wiring this is a twist handle?
Posted on Sep 29, 2008
  • TripleTauto
    TripleTauto Sep 29, 2008
    there is contacts in there that will get worn and/or the wiring can break from moving back and forth
    will just have to take switch apart and inspect
New GMC electric chainsaw runs until it try's to cut wood. Motor runs but chain dose not turn ? Turns if not on wood.!
problem in the safety clutch area
ensure that the safety bar is fully back and engaged before pressing trigger
the safety bar is that handle at you fingers when you are holding the the saw handle and by moving , flicking your fingers forward it stops the chain action
if that is fully engaged , it will require servicing by any accredited chainsaw repair shop
Apr 23, 2017 | Electric Garden
I have a chain saw 55 husqvarna and while the motor turn he stop suddenly often of the time when I put the brake and the motor is truning slowly he stop
Check to make sure the brake binder is not engaged...which is the same as saying: check and make sure the kickback brake handle is fully cocked. The handle should be oriented rearward towards the forward hand grip. If it is forward, pull it back stongly until it lockes in place. (Hint: also make sure the binder is released/brake cocked always before attempting to remove the brake assembly from the saw drive engine subassembly.)
Oct 04, 2014 | Husqvarna Chain Saw Models 51, 55
My motorguide trolling motor keeps tripping the 50 amp in line breaker every time I turn it on high speed. It is a 75 lb thrust digital tour model. When I take it out of the water and run it on high...
All motors will draw higher amperage with varying loads. Your hi speed motor winding has probably shorted some its winding's without having gone to ground. It probably needs to be replaced to get your hi speed back. I have run into similar problems in heavy commercial hydronic pumps. Best to have mechanic check it out. An OHM test with factory specs. will tell for sure.
Sep 04, 2013 | Electrical Supplies
I have a Motor Guide Brute 767, 67 lb thrust 24 volt trolling motor. It will only run at about half speed even with new batteries.
I believe you may have a bad low voltage circuit board problem. I do not think they make the board any longer but you may be able to convert it to work by bypassing the circuit board. I am working on one now.
Mar 22, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
I need to find out how to adjust my shifting linkage for a 1988 mercury mariner 60 hp. i don't have a diagram
Its not too bad to adjust, just takes patience and an assistant would be nice. You want to center the linkage in neutral so the throttle does not move immediately when you shift.
This can be adjusted with the motor off. You need to try it first by putting the Handshift in neutral and spinning the prop by hand. The prop should spin without locking into gear or making a "ticking noise" with the gears partially meshing. If there is a "ticking noise" you need to disconnect the shift cable; adjust it until the noise is gone. Then reattach it.
Now have your assistant move the Hand Throttle slightly forward, the gears should make a "ticking sound" before the throttle cable moves, and the gears should lock into forward before the throttle cable moves. If the Throttle cable moves too soon, you want to disconnect the Throttle cable and turn the knurled fitting to return the Throttle cable to a closed position. Easy does it with these adjustments.
If you go too far while adjusting the Forward gear it can show up on Reverse. But remember, you do not need much Throttle in the Reverse gear. Reverse is only for manuvering at slow speeds. You want low RPM for Trolling in Forward so you want a little slack in the Throttle in Forward gear.
Jul 17, 2010 | Boating
The switch keeps burning out and the motor turns about one turn and then will not turn again. Motorguide Trolling Motor Brute,767 67 lb thrust 12/24 volt Hyper Drive
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
Jul 01, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
1,261 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
