Question about Kenmore Elite 21086
Kenmore water problem?
Did you get it resolved?
Clive
Yes I did. It was the lid switch. It was a pain in the rear to fix but yes we got it. Thanks.
Posted on Sep 29, 2008
My Kenmore Elite comes up with F35 not sure what that means and locks my machine up
Hi
In your Kenmore F35 error indicates Analog Pressure Sensor Failure. To resolve this issue you have to start with checking the pressure hose and the air trap, try to clean them for any clogs and check if they are fixed correctly. After doing this if the issue is still not resolved then you'll have to check and replace the water level switch.
Thanks
Rylee
Oct 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite top load washer will not begin wash cycle and keeps flashing "FL" and beeping twice every few seconds. Tried unplugging it to see if the electronics would re-boot. How can i correct this...
Hi
Thanks for using FixYa. Error LF or FL means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 12, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite 22062 washer, code FL. FL flashes and motor hums for about a minute then shuts off. There is about 1 inch of water in the tub yet. I shut off cold and hot water and unplugged power over...
Hi
Thanks for using FixYa. Error LF indicates long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Kenmore 22062 Top Load Washer
F 24 error. What does that mean?
Hi
Thanks for using FixYa. F24 is a water temperature sensor error which is caused when the water temp. sensor value is out of range during the water heating step of the wash cycle. To resolve this issue you’ll have to check the water temperature sensor and its connections. If everything seems to be working fine then you’ll have to replace the water temp.sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore washer elite flashing LF...could someone please tell me what this is...????
Hi Rhonda,
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 23, 2010 | Kenmore 24032\24036 Top Load Washer
My kenmore dishwasher will not fill up all the way
Hi
Thanks for using FixYa. To start with check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. If the water inlet valve is bad you have to replace it, also check the main water line for clogs/obstructions. If still the issue is not resolved then it’s a bad float switch and needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 05, 2010 | Kenmore 24 in. 16019 Built-in Dishwasher
What is the sequence to reset our kenmore 16052
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 24 in. 16052 Built-in Dishwasher
Kenmore 600 with atc. water temp change
to change water temp when a cycle has started, pull the knob and reset the water temp, then move the dial to the desired setting. push knob in. resolved by trial and error!
Nov 05, 2009 | Maytag MAV5920E Top Load Washer
Kenmore 9550580 ice maker
try turning down water pressure or reduce flow into ice maker by turning tap partially off, this should resolve problem. Regards Advisor
Aug 23, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
