Question about Hotpoint  21.8 Cu. Ft. Top-Freezer Refrigerator
Hotpoint Top freezer model#RTW162TRW-1
The thermostat is always set at "5". I noticed that the freezer was not as cold as it should be. So I turned it up to "6" to see if it cut in. It did, but it doesn't seem to cut in unless I turn up. Do I need to replace thermostat?
  • 61 Answers
You shoulnt have to set the controls colder the 50% like 3 1/2 out of 7 / there are two controls one is in the freezer or should i say it sences freezer temp. this control actuly turns the compresor on and off the second is more a damper witch allows more or less are to be sent from the freezer to the cooler or bottom cabinet. Many many times i have seen people overfill there freezers witch causes similer troubles. the control is siply a switch that works on a presuized gas bellows. as the temp reduses in the bellow do to low tep the control opens. as it increases with heat the switch closes. turning the contol colder simply changes the values. most control fale when the will not shut off or will not turn on . veary rarely in between. your fride is also frost free and the defrost system may be in trouble , this will cause ice buid up in the freezer coil cousing a lack of air flow . so as you can see there is more involed then the turn of a nobe. to test the defrost system simple turn the timer into defrost or youl here it click / should be lokated in the top of the food copartment. see if the defrost ends within 1/2 hour . if not replase the timer.... hope this helped
Posted on Oct 07, 2008
Not Cooling properly...The dial at bottom left side of fridge---if I turn it will it help in cooling fridger more??
First the levels should never be set to the highest level? as this only stresses the compressor and runs to much cold air in only 1 compartment. If u have a cooling problem I would check my thermistors fridge and freezer side but check at very cold temperature not at room temperature. and check for continuity and for the OHMS rating as well according to ur schematic. also check ur cold control thermostat. and air flow control damper
Mar 21, 2015 | Hotpoint Refrigerators
What temperature should i have my top half fridge of my hotpoint fridge/ freezer as it is too cold and everything is freezing
A good setting is in the middle of the thermostat range. For example, if you have numbers from 1 to 9, 5 would be a good number. If this setting continues to freeze, look for a bad thermostat or temperature thermistor.
Oct 01, 2014 | Refrigerators
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Hotpoint model HM3151. Freezer is iced up!
Sounds like cold control thermostat or control Board is bad. Which ever one your model has v
Sep 05, 2017 | Refrigerators
Beko CDA543 F freezer always on?
noise sound like compressor mount are loose or rubber garment fell off that stops vibration or pump is bad internally call warranty get replaced if not a mounting problem of compressor
Mar 02, 2017 | Freezers
Diverter valve on Hotpoint FFA70 recieves no power, Fridge ok
Bonjour..Your system check (hot cold) is correct. Generally all new refrig/freezers cool only the freezer & bleed cold air off to cool the refrigerator. Most diverter/airflow dampers I have seen are mechanically operated for simplicity & to keep costs down. I would unload freezer and pull the panel off where you see the fan mounted. Go slow, don't drop any screws.You may not get them back. Look at the drain pan under the evap. coil. If it has ice that is built up in layers. Suspect the defrost termination thermostat. If the evap coil is clogged with heavy frost, suspect 1 the defrost timer and 2 the defrost heaters mounted on the evap. coil. Let me know how you make out.
Parts http://www.repairclinic.com/Refrigerator-Parts?s=t-Hotpoint+FFA70-%3d%3da4&z=50
Jul 02, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
The freezer works but the refigerator section does not. When you turn the temp switch for the refrigerator it will turn off the freezer also.
dont tuch the thermostat put it in normal setting!
now, check if your fan in the frezer working, if it is working che3ck the thermostat unit and heater in the frezer unit also need to see if the frosting is eaven all over in the frezer side..
contact me at www.911servicetoday.com
Dec 30, 2009 | Refrigerators
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
May 25, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
hi thanks for the question you problem could be a no defrost problem remove the floor of the freezer 4 screws lift from back to front remove foam if its all frosted up you have a defrost problem a bad fan motor also can cause this it could also be stuck in ice if so use hair blower and thaw dry it real good re assemble and try again thanks the appliance doc
Sep 22, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint FZA50 Freezer not cold enough
try it on max setting. lint clogging up stuff in the back? needs defrosting? low on refrigerant (freon)? call repairman for that last one
Jul 10, 2007 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Hotpoint  21.8 Cu. Ft. Top-Freezer Refrigerator Logo
121 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
