Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
E-4 54040990 Cannot record on this disc
When disc is first put in the unit. Then if you try to "quick record" I get E-21.
Brand new discs, different brands, discs that already have been recorded on, doesn't matter.
  • 7 more comments
  • Anonymous Oct 01, 2008
    System has been working fine for a year. One day it wont record and gives me an E-4 error. Still plays previous formatted and recorded discs at SLP, but wont record any more.
  • kimlvn2 Oct 05, 2008
    I get the following messages when trying to record: E3 54037380 or E4 54037380.
  • bonitawallac Oct 14, 2008
    My DVD recorder shows an E-4 54037380 error - Can not record on this disc. It does not matter what kind of DVD disc I use. It has worked perfectly in the past and will still play recorded DVD's of the same format
    that were recorded in the past. I have checked all input and output cords, and even reset the clock.
  • kittenes Oct 17, 2008
    Same recording error as the others, How do I fix it?
  • psubag Oct 29, 2008
    I got a lens cleaner disc, and it still wouldn't work. I put a new disc in and REPEATEDLY took it out and put it back in, turned the power off and on, and it finally worked. Tried another disc, and got the error message again. I just kept "feeding" the disc back in until it finally formatted. I did NOT turn the power off and on the 2nd time. I think it took about 4 tries before it worked. Once I get a disc to work, I dont have any more trouble with it.
  • Anonymous Oct 31, 2008
    i thoought it mihght be an issue with the disk so went and bought lots of different brands to macht the emblems engraved in thefront of the unit.i have s-video in to dvd unit and i could record veiwed material from a dvr from suddenlink.now no matter what i do,i get the above code e 4 54040990 error in recording.
  • Anonymous Nov 14, 2008
    I HAVE PUT A NEW DISC OF MANY MAKES AND STILL GET E 4 54040990
  • tr24 May 08, 2009
    Magnavox MVR20V6 DVD Recorder/VCR Combo w/Progressive Scan
    I get the following error when attempting to record to new DVD -R:
    E4 54037380
    I will look at page 30 of the manual as recommended and attempt to clean lens and try again.
  • shadiedog378 Aug 24, 2012
    same as every1 e-4 54040990 can play prev. disc and regular dvds but can't format my old recordings I didn't finalize or anything even got a grex thinking macro-vision but still same problem can't record at all i think if i had a tape i could put it in and press play stop and record dvd from input used to work on old vcrs since a combo that's how i had to use my playstation 20 yrs ago lol any help will b apriciated plus if you research the xbox 360 not reading disc maby same problem but it does play even the unformatted disc recorded from this pye video vcr combo model # py90vg
I had this problem with my Toshiba DVR16 recorder; I was unable to format new DVD-RW discs even though old ones worked fine.
Initially I thought the laser lens was dirty, but no amount of lens cleaning helped. Then I thought the rated disk speed must be to blame, since it was some 4x disks that first presented the problem. But then I tried 2x disks and the problem persisted. So some aspect of the manufacture of these disks must have changed in recent months.
Anyway, the solution I discovered was to perform an 'erase' operation on each disk using a program on my PC called ImgBurn. This is a free program, which can be downloaded from imgburn.com. Just select Tools > Drive > Erase > Quick. Once that's done (it only takes seconds), take the disk out of your PC and pop it in your DVD writer, whereupon it should start its own format routine.
This has worked for me on 3 different brands of disk (Sony, Memorex, Datawrite). Which is just as well, as I was on the verge of throwing the DVD recorder out of the window. Hope it works for you.
<Neil G.>
Posted on Oct 06, 2009
  • JD McLeod
    JD McLeod Jun 10, 2012
    Neil G.'s solution was a waste of time and bandwidth (to download ImgBurn) for me. After erasing a DVD+R the DVD recorder wouldn't even TRY to record onto the disk. Things went from the original E 4 54040990 error straight to Cannot Record On This Disk. Thank you for another coaster.
    Scholar:
  • 188 Answers
There is an error code list on about page 30 of the manual. You can download the manual here:
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Looking at the recording setups, it might be a clock or timer issue or an input setting changed.
Posted on Oct 03, 2008
I had the same issue and called Tech Support with no luck. I'm not sure which worked, but I used a CD/DVD lens cleaner and tried a new disk (DVD-R) and I have not had a problem since.
Thanks
Avi
Posted on Oct 28, 2008
  • Tracee
    Tracee Mar 02, 2015
    Yep, just needed cleaning and now it works like a charm. Thanks Avi
Don't know if this help but I noticed that my dvd writer got the same code over and over again but It didn't give me the code when I used any brand dvd+-rw. It only does it to DVD+- r. Even the manual says it will write a Sony dvd+r but it errors but it will write a Sony dvdrw, go figure. I guess I'll just buy dvdrw for now,
Posted on Jan 03, 2010
This happens to me a lot & I think it has to do with the fact that I use discs multiple times & they have also been used to store data from the computer at one time. (Don't ask me anything technical this is just based on my observations) If it is a blank disc &/or it has content that you don't mind losing you can try to erase the disc (use disc erase in the disc edit menu). Even if a disc is "blank" if it's been used before to store data it may need to be reformatted. Usually after I do that the disc is recordable. I've never had this problem with brand new dics so I can't help out there. Sometimes the disc may be scratched & if you use one of those scratch repair kits & clean the DVD lens routinely that may also help. FYI this is based on using +RW discs
Hope this helps
Posted on Nov 01, 2008
I have been trying to erase previous recordings made in 2009 and 2010. When I set erase in motion,I get message "Recording error.Can not record on this discE 4 54040990"
They have to be DVD/RW's (rewritables) otherwise you cant erase, some DVD's have an RW next to the DVD etch but that doesn't mean re-writable, you can usually tell by the color of the dye used the re-writeables look different
Sep 28, 2014 | Televison & Video
We have a Toshiba D-VR40SF DVD/VCR combo. It will record happily on a Sony x1/x2 DVD providing it is a disc we have already formatted and recorded on. But with new discs from the same pack, (or new discs...
Since it is doing this with both old disks and new disks, it is not discriminating and we cannot say it is a media incompatibility issue. I just think that the Electronics may be fubar. Wait, I think it has lost the ability to format the disk. That is what your old new disks and new disks have in common - they are not formatted!
Sep 20, 2017 | Computers & Internet
I recently purchased a pack of staples brand DVD RW's instead of the name brand ones I usually use. When I insert them into the player I get an error message stating that it cannot record on this disc ( E...
Please check if your blank DVD's are dual layer ( DL ) 8.5 GB disc. If so your player does not support dual layer writing. It will record only on 4.7GB single layer blank discs.
Apr 22, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording error E 4 54040990 keeps popping up
Try using a DVD / CD cleaner disc in the unit - this might fix the problem once cleaned the unit should work fine.
Feb 24, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Error code E 4 54040990
jamesgranger - I think your DVD recorder is still having trouble reading the DVD+RW. It should not have a problem using a DVD+RW many times. Try taking the DVD+RW and put it in your computer. Find it in Explorer, right-click and choose "Erase". Then try to record to it using the DVD recorder again. If it works, you can use this to record, though it might be a pain.
The fact that your machine will record to the +R means that it works. Failing to work (record or erase) on the +RW means it's not reading it well. I would try running the lens cleaner again if it were mine. Also, I would make sure that the unit didn't have a lot of dust in it. If you can, power it off and use some spray-air to be sure there's no dust. You may have cleaned the lens, but if there's a lot of dust inside the unit, it will quickly find it's way back to the lens and you'll have the same problem. Michael
Jul 09, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Error message E54040990
Make sure that the discs are right for the unit. As this unit is now absolete you may have trouble finding discs. For one time write, try to find Verbatim Movie Discs 1x-8x. Try Microcenter. Use DVD RW from Maxell 1x-2x. I believe they are still available at walmart.
Aug 01, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Error code
Try using a DVD / CD cleaner disc in the unit - this might fix the problem.
Post Back here again..
Thank you
May 21, 2008 | Radio Shack Accurian ADR-0106
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Apr 16, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
6,486 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
