Question about Maytag Atlantis MAV6000 Top Load Washer
I NEED TO REPLACE SOME OF THE TRANSMITION FLUID THAT LEAKED OUT OF MY ROPER WASHING MACHINE WHEN I LEFT IT ON ITS SIDE? WHAT TYPE CAN I USE
I NEED TO REPLACE SOME OF THE TRANSMISSION ION FLUID THAT LEAKED OUT OF MY ROPER WASHING MACHINE WHEN I LEFT IT ON ITS SIDE? WHAT TYPE OF FLUID CAN I USE?
  • 32 Answers
Any automobile automatic trans fluid would do fine but i am not sure how you are going to replace it.the fluid you lost when it was turned on it's side came out the vent hole on the top.unless you lost a huge amount of fluid,i would not bother.i have seen 20yr old whirlpool's(roper manufacturer)that have lost 2/3rd's of their fluid due to a bad seal run with no trans troubles at all.if you only lost a pint or less,the mach will be fine.good luck
Posted on Sep 30, 2008
How murch transmition afer draining i have to replace?
Need a trans flush machine to actually replace all fluid.
Aug 26, 2016 | Cars & Trucks
Water leaked into transmission and transmition oil into radiator
Your transmission cooler is cracked. Discontinue using that cooler immediately. Get some caps, cap off the cooler. Replace the cooler with an after unit vor about $80.00. Change the transmission fluid and engine coolant before you drive any further.
Sep 19, 2011 | 1996 Ford Explorer
I was changing the oil and i mistakingly drained the transmition fluid as well and now i cant locate where to replace the transmtion fluid
On the side of the transmission there should be a bolt or a hex head that you have to unscrew and the will allow you to pump the trans fluid into the transmission. You will need some type of a pump to add fluid, I would get a Haynes or Chilton manual to make sure that you add only the proper amount of fluid to your vehicle
May 29, 2011 | Pontiac G6 Cars & Trucks
I have a roper wash machine .I need to look at a part in side the machine but do not know how to get the back off it?
The back does not come off.
Totally front servicable.
Here is a tutorial that wull get you inside. Be aware there are 3 locations for the screws mounting the top consule. Bottom left and right, bottom left and right but hidden by plastic end caps, and bottom rear.
http://www.davesrepair.com/DIYhelp/DIY285753pf.htm
Feb 25, 2010 | Roper Washing Machines
I have a Roper Washer Model RTW4340SQD that
The lid switch is on the top left side of the top cover. If it is bad the machine will fill and stop. The lid switch must be good for the machine to agitate and spin.
Nov 01, 2009 | Roper RTW4300SQ Top Load Washer
When changing my transmition fiter and fluid I removed the old filter but the orange ring around the top of the filter stayed lodged inside of the transmition. I couldn't put the new filter on so I left...
You should really get the old orange gasket/ring out and replace it. I'm glad you are trying to do this yourself because this is a very simple process. Change the filter or clean it with a Gumout type solution. Hope this helps and once again I'm glad your doing this. Transmission tuneups are very important to the vehicle. Good luck.
Aug 29, 2009 | 1993 Lincoln Town Car
Roper washing machine type 107 won't fill up but 3
check the pressure switch, and the water level sensor
Update ma about your progress
Jul 23, 2009 | Washing Machines
Clothes still too wet after spin
Sounds like the trans has leaked oil onto the clutch. Lean machine back and look at inside of cabinet about 8 inches up. If you see oil spatter, then you need a transmition and clutch. It's usually cheaper to buy a new one.
Apr 23, 2009 | Kenmore 24032\24036 Top Load Washer
My washing machine wont spin
How do you open the top to replace the lid switch?
Oct 11, 2008 | Roper RAS6233KQ Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
132 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
