Question about PC Chips P21G (881038000916) Motherboard
Help !!!! BLUE SCREEN While Installing Windows Xp
I've just bought a P21g, and when installing XP after copying all required files and it starts windows I get the dreaed blue screen of death. some times it's just the standard but others it's the IRQ_Not_equal so an so
H/W is
CPU: 3 Ghz Intel
! Gb Ram
80 Gb Seagate HDD
Radion 9250 Graphics
Can some one please shead some light on problem. Supplier is useless.
  • 781 Answers
This is a long shot but set your BIOS to default and try
I have installed windows XP on machines with only 256MB ram had to change disk a few times but got it done
Your should have sufficient ram not to I think you have a M/board conflict try removing everything except what you need to install windows
Posted on Sep 29, 2008
I want to install windows xp on dell inspiron mini 1018 but i am not able to install.some blue screen comes.please help
turn off your antivirus before you try to revert back to xp. your system antivirus might see this as an attack on your windows 7,thus it won't allow you to install a different system.
Feb 25, 2012 | Dell Inspiron Mini 10 Netbook
Blue screen error
I see ..either teh installation didnt complete the loading of the files..or you didnt format the Hdd proper...try to reformat it in the NTFS normal mode...and change the installation cd ..cause in the proces there might have been a file it couldn't copy ..and skip it ...keep trying cause sometimes it does that ...if the server went fine ..this means that the HDD its ok ..and the problem is the installation disk ...with xp on ...
Aug 04, 2009 | HP Pavilion zd8000 Notebook
The problem is the driver for the sata hard drive. You would need to get that from the dell site and put it on a floppy disk, then at the start of the windows install select to install that driver. I ended up just installing the rc version of windows 7 and it worked out fine.
Mar 02, 2009 | Dell Optiplex GX280 (99301) Motherboard
Problem in XP installation in the HP presario Note book
Sata hard disk does not require driver, however the sata controller which belong to any manufacturer may require. You have to go to driver cdrom, browse for IDE OR SATA if you cannot find it the clue is "RAID" find the RAID driver, you will also find the sata controller driver
example only:, si3112.inf, siblabla.bla....
copy all the files in folder (do not copy folder!! only files). Then put floppy disk in drive, make sure you boot from cd-rom.
Start XP installation then follow:
Press F6 for third party SCSI or driver installation at the beginning of text mode installation. Press 's' when setup asks if you want to specify an additional device, and insert the diskette then press 'Enter'. From the menu presented next, select the controller installation process that corresponds to the version of Windows being installed and press 'Enter'.
4. Press 'Enter' again when prompted to continue on with text mode setup.
5. Follow the setup instructions to select your choice for partition and file system.
6. After setup examines your disks, it will copy files from the CD to the hard drive selected above and restart the system. After restart the setup process will resume to finish the installation.
Good Luck
Jan 07, 2009 | HP Pavilion dv6000z Notebook
Installation error
install windows xp sp3,
Nov 27, 2008 | Compaq Computers & Internet
I get the Blus screen when trying to install a fresh copy of XP on my nx8220
If you are installing a fresh copy, you should boot from cd, and not start it from windows. It is less error prone.
Oct 27, 2008 | HP Compaq nx8220 Notebook
Windows Xp installation
IRQL_NOT_LESS_OR_EQUAL is a hardware error.
might be processor is over heating or you have a bad ram.
please check this article for more explanation on this issue.
Oct 27, 2007 | Microsoft Windows XP Professional With...
Installing windows xp home edition
i would hazard a guess that you are using a pirated corporate copy of windows, as there are 2 files on the disc that cannot be copied so you should just start again and when prompted for the two files to be installed press esc to skip it. You wont be able to get any support or updates from microsoft and unless service pack 2 is already built in the instalation which i doubt, the product key of the software will have to be changed in order to install it.
Sep 16, 2007 | Microsoft Windows XP Professional With...
PC Chips P21G (881038000916) Motherboard Logo
915 people viewed this question
Top PC Chips Computers & Internet Experts
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
