Question about Lexmark MFP-X3470 All-In-One InkJet Printer
Lexmark x3470 has cover open in display will not do anything now
Cover open shown in display unit will not work now
  • Anonymous Oct 03, 2008
    I opened it to change the cartridge. I closed it and it just says "COVER OPEN" and the printer does not work any more.
  • SueyBird Mar 29, 2009
    I have the same problem! "Cover open"!!! Now the printer won t even turn off!!!I had to unplug it and buy a new WiFi printer, but I would love to fix my X3470.
    Any ideas???
You need to open cover and undo and remove the grey cover inside the printer as there is a switch at back of machine which has *** off
Posted on May 06, 2009
I bought a x3470 printer second hand. It wont respond when i press buttons on printer. It says door open in display window.
Here is a great article on how to try to resolve the cover open error on the Lexmark X3470. http://bit.ly/aoOtEP
Feb 27, 2010 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470 printer says "cover open" and it will not do anything. Curtis
Try these as I found them from Lexmark's website
Solution What you will see
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
Possible cause of the error
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
What to do
Take the following steps to try to determine if there is a hardware fault:
Steps Actions 1 Remove and replace the cartridges from the printer. 2 Disconnect the power cable and the USB cable. 3 Check that the power cable is plugged directly into a wall socket. 4 Reconnect the power cable. 5 Close the printer cover. 6 If the error persists, please contact Lexmark Technical Support for further instructions.
Nov 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark x3470
Try looking around the edges of the cover or in the hinge area for a switch that may be stuck. Most covers have a switch to indicate that the cover is open, the cover may not be seated properly or the switch may be stuck in the open position.
Aug 30, 2009 | Lexmark X3470 All-In-One InkJet Printer
Printer displays "cover open" but it isnt. printer will not do anything
try to of the power and din open all parts the printer and din close again after that on again did you try it
Jul 04, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open is on display
put your finger on the second hole on the top from the right and press the switch (it's small, gotta try a little...), when the display changes, press copy and close the door... it just worked for me!!
good luck
Apr 02, 2009 | Lexmark X3470 All-In-One InkJet Printer
LEXMARK 3470 COVER OPEN
there is a switch actuator on these cover try to see if you can find any piece of tab that actuate these switches, unless the cover is really closed ensure that it is fully flat
cheers
Sep 17, 2008 | Lexmark X3470 All-In-One InkJet Printer
Cover open
see your printer cover for broken.
Mar 18, 2008 | Lexmark X3470 All-In-One InkJet Printer
COVER OPEN
There is a plastic lever in the back of the scanner where it comes into contact with a part made to push the lever when closed to work the switch. It is a poor design. The lever fits over the small micro-switch very loosly and the tabs wear out really quick. Lexmark will not send another lever. They state buy another printer. If you are real careful, you can put the lever back on the switch and hold it in place while you close the lid.
Oct 27, 2007 | Lexmark X3470 All-In-One InkJet Printer
Open Questions:
Lexmark MFP-X3470 All-In-One InkJet Printer Logo
451 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
