Question about Acer AL1714 17" LCD Monitor
Desktop icons appear as a shadow on all windows.
Icons are easier to see on darker windows, but they are always there. I'm running Vista on a new computer with an older Acer AL1714 monitor.
capnandy
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 149 Answers
SIMPLE !! The "shadowing" you talk about is due to cables in back of your computer, touching or too close together. I had this happen to mine. I moved the cables apart, and no more shadows !! Sounds too easy, but it works. Takes a few seconds. Immediate results.
Posted on Nov 06, 2014
  • 12 Answers
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Posted on Feb 07, 2010
Make icons smaller
Assuming you're talking about your desktop icons, here's how that can be done:
    1.If you're using Windows Vista or higher, you just need to right click on the desktop and point to view and the select the size that you want.
    2.If you're using Windows XP, follow the instructions mentioned below:
    i.Right-click any empty space on the desktop. A context menu will appear. Select Properties.
    ii.Select the Appearance tab in the Display Properties dialog, then click the Advanced button.
    iii.In the Advanced Appearance dialog, select "Icon" from the Item drop-down menu. Select new size in the Size field to the right of the drop-down menu.
    GuruAid
Apr 14, 2014 | Computers & Internet
Tip
Create Desktop Shutdown/Lock/Restart/Hibernate Shortcut Icons In Vista
1. Right click an empty area of your Desktop
2. Select New>> Shortcut
3. In the text box titled: "Type the location of the item:" Enter the Command for the particular shortcut you would like to create. I've listed all of the commands below that activate their respective shortcut:
Hibernate rundll32.exe PowrProf.dll,SetSuspendState
Lock Rundll32.exe User32.dll,LockWorkStation
Restart Shutdown.exe -r -t 00
Shutdown Shutdown.exe -s -t 00
Sleep rundll32.exe powrprof.dll,SetSuspendState Sleep
4. Once you've entered the command, click "Next"
5. Vista will now ask you what you would like to name your shortcut. I've always just given it the name of its function (EG: Shutdown or Shutdown System).
6. Once you have named you shortcut, click "Finish". Your new shortcut will now reside on your Desktop. Simply double click the icon to activate the command.
Note: If you do not like the look of the "default" icon that Vista has given it, you can change the icon to a different one. Here's how:
1. Right click the shortcut icon
2. Select Properties
3. The shortcut properties window will now be displayed. Click the "Change Icon" button.
4. The "Change Icon" window will now appear. Here, you can select from the many available system icons. Click the icon that you would like to use as your shortcut icon and then click OK.
Your Desktop shortcut icon will now revert to the selected system icon.
That's it! Have fun!
on Oct 08, 2010 | Computers & Internet
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
My kids have put a picture on my desktop and i don't have no icons on it I'm trying to get the icons back on my desktop
Move your mouse to the bottom of the screen and right-click once. Then you should have a "Show Desktop" option or un-check the "Hide Desktop icons" Click that and all your icons should re-appear. Unless of course they actually deleted your icons :'
Feb 28, 2011 | Dell Dimension C521 PC Desktop
How do I fix the size of my icons and make the internet fit to size
How to resize Vista desktop icons
One of the complaints I hear about the Vista GUI is that "the icons are too big." Well, fixing that is a simple matter. Here's how:
Right click an empty space on the desktop.
Select View.
Click Classic Icons.
Another way is to use the scroll wheel on your mouse or trackball. With the cursor on the desktop, press and hold the CTRL key and scroll the wheel to make icons larger or smaller.
I hope someone having that problem will read this thread.
Cheers!
Jun 24, 2010 | Microsoft Windows Vista Home Basic Edition...
Desktop Icons have shadows and a blue box around title. How do i get rid of this ?
This border on desktop icons can be created when the desktop items have been locked, to unlock the desktop web items right click on an empty area of your desktop. Now select Arrange icons by and uncheck 'Lock web items on desktop' if it has a little tick next to it. If you did not have a tick here then Right click on your my computer icon and view its properties, now click the advanced tab and then on the settings button under performance. Now on the visual effects tab scroll down the list of effects to 'use drop shadows for icon labels on desktop' and put a tick in the box next to it, then click ok. This should remove the shadow border from your desktop icons.
refer to:
http://www.ikarmatech.com
Sep 08, 2009 | Microsoft Windows XP Professional for PC
Actual Owner Site Icons Do Not Appear on My Desktop
all you need do is right click on the icon and click on properties, you will the information you needed from there. good luck
Jun 05, 2009 | Microsoft Computers & Internet
Cannot see my desktop
Please try these steps to solve your problem:
1) Press Ctrl+Alt+Del to run the Task Manager
2) Click on "File" on the Task Manager upper menu
3) Click on "New Task (Run)" option, Run window should appear
4) Type "explorer" without the quote, on the Run window
5) Your start menu and icon on desktop should now appears
hope it helps :D
Apr 29, 2008 | ASUS A9RP Notebook
No icons on the desktop
hi if you right click your mouse on the center of the desktop a menu will come up highlight the one that says arrange icons by another menu will appear make sure that show desktop icons is checked to the left if is isnt check it by clicking on it and the icons will appear. hope this helps.
Jan 05, 2008 | Microsoft Windows Vista Ultimate Edition
Desktop icons lost
Sadly, there is no straightforward command you can use to recover them, but well, there are three ways, really, that you can get your icons back, depending on which ones were lost, that you are referring to. for this, I'm assuming you're running a more recent version of Windows.
----- For Windows XP ------
1) for recently deleted icons- check your Recycle bin, they could still be there.
2)for system-installed icons, such as My Computer, and Internet Explorer- you can recover these by going into your Display Properties (Start -> Control Panel -> Display). Select the Desktop tab, and click on Customize Desktop. Make sure the "General" tab is selected, then, under the "Desktop icons" section, tick off the icons you want to restore. click on "Ok" when you're finished, and Presto! those icons are up on your screen.
3)If the above two options don't work, you may have to add them manually ( a pain, I know). To add a shortcut in this fashion, right-click anywhere on the desktop, and select New -> Shortcut. you will have another window appear on your screen, asking you where the file you are making a shortcut to is located, and what you want to call it. follow the steps, and when you're finished, you should have a working icon. (another option would be to reinstall the software that made the icons, but that's also a pain in itself.).
----for windows vista ----
1) check the Recycle Bin (same procedure as Windows Xp, although, if your recycle bin option is deleted, then you have a problem that can be solved by using #2)
2) For system-installed shortcuts- follow This excellent tutorial.
3)Manually installing shortcuts- same as for XP.
Dec 17, 2007 | Computers & Internet
Acer AL1714 17" LCD Monitor Logo
232 people viewed this question
Brian Sullivan
Brian Sullivan
Mohammed Ebrahim M
Mohammed Ebrahim M
