Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
Wd making noises not usually present
When I plug "my Book" into the USB port, it starts making loud noises that i can hear in the other room. My computer wont recognize it either, I have tried to toggle the power on/off but this wont work. I have alot of pictures and schoolwork on there that I dont want to lose. I have also disconnected the power to the unit and that didnt work either. What should my next step be ?
  • jenhutsko Dec 19, 2008
    I have the same problem happening on my WD hard drive - myBook Essential 160 GB. I just want to get my files off of it now, and get something different. How can I take the drive apart? It's in an enclosed case, and no obvious ways to take it apart.
    Thanks.
    Genius:
  • 1,605 Answers
If possible, open the "my Book" and take put the hard drive, connect it ot your PC as secondary internal hard drive.
Posted on Oct 15, 2008
I plug in my WD external hard drive, i hear the chime saying the computer knows i plugged something in, but i see no icon to click on to open it. HELP! i have soooooo much information on this thing!
- try plug in a normal usb port (usb2)
- try open up the device manager, look for your WD and delete it.
then unplug and plug back.
try goto control panels->administrative tools->computer management->disk management
and see if your wd appears there. if yes, try change the drive letter assignment.
Jun 14, 2011 | Western Digital My Book 3.0 WDBAAK0010HCH...
Plug in cord and just hear clicking noise not connecting to a computer
This means that the WD could is trying to connect to the computer but looses the connection. Try plugging the usb cord in another usb slot on your computer. Or try using another cable. Make sure the WD is not giving out any red led light on the device.
Mar 01, 2011 | Western Digital My Passport Essential...
My WD hard drive shows up on windows explorer but when I click on the icon it states that I need to format the drive in order to read it. I have loads of precious data on this hard drive. How can I...
I had the same problems with mine. It got to the point that the drive wouldn't even spin up all the time. I got lucky one day, and it did spin up & I was able to get my data off the drive. Counting this unit, it is my fourth WD HDD failure! Needless to say, there are no more WD drives in my house!! Are you plugged into a "native" USB port? Try that if you are using a hub. Also try unplugging the USB cord into the unit and plugging it back in again alternating with turning it on and off using the big button on the front. It isn't just a HDD in a case. There is a weird electronics board inside that connects and controls the drive. NOT a regular IDE or SATA connection, so you can't just take it out and hook it up using an IDE to USB and power supply to get your data off. Do other USB accessories run OK on your USB ports? Sometimes THEY get strange and won't work or won't work correctly. Disconnect the "My Book" USB cord, shut your computer off, pull the power cord completely out of your computer, press the start button on your computer for 5 seconds. Put the power cord back in, start your computer and reconnect the USB to the My Book. Doing the above will usually fix the USB ports that have gotten corrupted for whatever the reason. You might also try running it on another computer and see if you get the same results. Hope any of this will help. Let me know if it does, and please rate me accordingly. Good luck....I know all too well what it is like to loose data.
Jan 08, 2010 | Western Digital My Book Essential Edition...
Won't Boot up
An electrical surge would normally burn an enclosure's power electronics, making it incapable of "translating" between your PC USB port and the internal hard disk.
Assuming it's not the USB port which died (try another USB slot to be sure), the disk and its data may be accessed in two ways.
One: dismantle the WD unit, extract the hard disk, and plug it internally into a desktop PC with an appropriate free internal interface (EIDE or SATA), so that no translation is necessary. Data access will also be way faster.
Two: again extract the hard disk, but remount it into an empty USB enclosure - ideally another WD - so that the USB-to-disk translation will take place once more.
Option #2 may be undertaken by the majority of competent PC shop clerks and should cost between US$ 20 and US$ 50, USB enclosure included. Repair shops will often have empty enclosures (maybe even WD's) with good electronics where the internal disk died, e.g. because of a fall.
Oct 09, 2009 | Western Digital My Book Essential 1TB...
I have recently bought a Belkin N+ Wireless Modem-Router (model F5D8635-4 v1). It comes with the USB port and I bought a WD 1Tb drive to connect with it. I added the WD drive (92.168.2.1My Book in my...
  • First off, the WD hard drive was meant to be connected to a computer.
  • Therefore connect it to the fastest computer you have or the one running the network.
  • Make that drive a network drive.
  • Set the router to handle DHCP using the web based interface (192.168.1.1 on a linksys router, check your manual for the IP address belkin)
  • The drive apparently has three volumes on it: X: Y: and Z: (network drives)
  • I would backup the WD drive and reformat in NTFS format
  • I dont believe that these drives were meant to be networked. Therefore you get what you get....
Good Luck
Jeff
Sep 14, 2009 | Computers & Internet
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
My Panasonic TH42PZ80 makes a slight buzzing noise when switched on - is this usual or is there a problem?
If the buzzing is coming from the set itself rather than the speakers, then this is normal. The bussing should only be loud enough to hear when you are close to the set. If it is loud enough to hear from across the room, it is not normal and could be a sign that the power supply is starting to fail. Which case best describes your situation?
Dan
Dec 15, 2008 | Televison & Video
WD My Book 1TB, not recognised by XP
Appreciate the direct "Ask Me".
A couple of ideas:
  • initially, confirm that it is the PC's USB ports that is the issue by trying the WD on another PC;
  • try plugging in a flashdrive, camera to your PC's USB port;
  • if it has been verified that the WD works in other PCs and that the USB port of your computer works, then it could be a registry entry.
Please open "regedit":
  • go to HKLM\system\currentcontrolset\services\USBstor;
  • check the value of the DWORD "Start" it should be 3;
  • If the DWORD "Start" does not exist, pls create it. Right click, New, DWORD value, Start, Value Data = 3.
Incidentally, there is Microsoft KB about disabled/disabling USB here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 26, 2008 | Western Digital My Book Essential Edition...
WD my book making faint ticking noises and flashing
it is possibly because the usb port you are connecting to is not receiving enough power to power the hard drive and use it at the same time. try another port or check on another computer else probably have to buy a new one
Sep 11, 2008 | Western Digital 320GB MyBook External USB...
WD My Book is acting very strange when plugged in.
Guys there is an internal hard drive inside this unit. Simply take apart the enclosure and use this drive. There seems to be a power design flaw. Your information should still be there!!!
Dec 27, 2007 | Western Digital My Book Essential Edition...
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
169 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
