If my car is blowing air but it isn't cold what's wrong?
    Scholar:
  • 121 Answers
Either the compressor is not coming on or your low on refrigerant. To check under the hood on the suction line (line that gets cold and sweats) by the fire wall usually on the passenger side you'll see a metal cylinder. On there is a lead with two wires coming from it remove this and jump it with a small wire or paper clip or bread tie anything metal this will not shock you. With the motor and a/c on if your compressor clicks in than your low on refrigerant, if it doesn't your compressor is bad.
Posted on Sep 30, 2008
Air conditioner isn't blowing out cold air
might need to be recharged and might have a leak in the system. take it and get it checked
Mar 16, 2013 | 2001 GMC Jimmy
My heat isn't working..the fan blows cold air
Depending on the year make and model, it could be a blend door problem if the heater hoses are hot.
Oct 08, 2012 | Cars & Trucks
My GE model GSH25JFTCBB side by side is not cooling in the fridge side. Freezer seems to be doing fine. What could be wrong
you could have a defrost problem,a bad damper,bad computer board.first thing,open the freezer door,do you hear the fan blowing in there?you should,if not the evap fan motor is bad,if it's blowing touch the back inside wall of the freezer to see if any frost or like snow is on it,from the bottom up in the freezer remove the second bin of food and touch the back inside wall with your hand,if it has frost or snow you have a defrost problem,bad defrost thermostat,heater,sensor or board,if there isn't anything on the wall then you have a bad damper,all that happens is the evaporator coil in the freezer gets cold,then the evaporator fan in the freezer blows the cold air over into the fridge section,you have a damper in your machine that opens and closes when it's cold enough or when it needs to get colder,the door on the damper isn't opening to let the cold air in when it calls for cold air.if you can write back and let me know what you find and hopefully we can get it fixed.
Sep 15, 2012 | GE Refrigerators
Blows cold when first started and then blowes warm
I would replace the AC compressor cycling switch it may be sticking have seen it a number of times. The switch is located in the receiver dryer on the passenger side of the engine compartment. See picture below.
If this isn't the problem the AC compressor relay may also cause this, flip a coin.
Sep 13, 2012 | 1999 Ford Taurus
Air conditioner
Check whether the warm air isn't going in with the cold air .Coolant line that runs into the firewall on the passenger side of the engine which is toward the bottom half of the firewall on the passenger side. If there is warm air going into the vents with the cold air then it blows warm air. You may have to shut it manually because it gets stuck sometime. Check it out.
Jul 24, 2012 | 2005 Honda Accord
When your heater blows cold air
flush the cooling system, probably clogged. happened to me a bit ago with a 99 cherrokee. hope it helps ya.
Dec 18, 2011 | 1999 Ford Taurus
1990 toyota 4runner heater is blowing cold air
could be your heater core, um try checking the heater assembly in the dash, something may have broke so the heat isn't being switched over, and it is staying on cold. Regularly check the fluids in the motor and top up as needed
Nov 21, 2011 | 1990 Toyota 4Runner
Air conditioner light inside truck comes on but blows only regular air.. not cold at all
It isn't blowing AC at all, just air. See if your compressor is turning with the belts when the system is engaged. Not just the pully but the compressor.
Jun 08, 2011 | 2006 Dodge Ram 3500 Truck
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
