Question about Microsoft Xbox 360 Console
2 red lites
Wot can i do about this problem
thanks
Looks like you have the red ring of death so get to your local computer expert now!
Posted on Sep 29, 2008
What is the factory prop for a 2005 Sylvan V-160 with a 2005 Johnson 70hp fourstroke
It all depends on what your using your boat for. Fishing, sport or pleasure or all of above. What kind of load you have. How many people, how much fuel or how big is your cooler. The most important thing is if your prop is running in the (W.O.T.) wide open throttle numbers for your engine. Your numbers are; 5200 - 5800 rpm's. The factory or for the most part, the dealer will put a conservative prop on. A aluminum three (3) blade -13.25 x 17 or 13 x 19 cupped. For a heavier load (lift,thrust, hole shot) you can run a 13.75 x 15 or for a light load (high speed) you could run a 12.75 x 21. More than likely a 13 x 19 cupped is what will run the best being that Sylvan is a fast planing hull. A four (4) blade propeller will give you a better hole shot and better mid - range control but is rarely to never put on at the factory. That only happens at the dealer and it's usually from profit margin on stainless steel or personal preference. The maximum horse power output on your motor will be at 5400-5600 rpm's.
******** (W.O.T.) Wide Open Throttle Numbers ********
The propeller pitch and the gear ratio of the engine sets the burn on the motor. It's got nothing to do with anything except proper consumption of fuel on the engine. Some people will say" Well I never go that fast or I only cruise at 4000" That dose not matter, it's set for...... PROPER CONSUMPTION OF FUEL ONLY. If you are not running in the W.O.T. numbers you are running rich or lean, either way you will blow up your engine.
To find your W.O.T. numbers: A new or reconditioned propeller only...no damage.
(1)Run your boat as fast as it will go, throttle all the way home. Conditions to your favor (wind to your back, water like glass, little to no chop).
(2)Trim the engine down to ninety (90) degrees off the stern, prop horizontal to the hull. The stern will lift and the bow will plow and you will lose speed.
(3)Look at the tachometer only, not the speedometer, just the tachometer. That is your (W.O.T.) wide open throttle number. Trimmed up will throw your numbers out by about three (3) hundred so as long as you are in your W.O.T. numbers pushing 5800 plus is ok as long as you don't hit your rev limiter, which is usually 6050 or a little higher.
Thanks for you question. propguy513
Apr 08, 2017 | Johnson Boating
Only Rev's up to 8k RPM
wot do you mean by ( header ) , do you mean a tuned exhaust system or a tuned cylinder head ?? if exhaust then yes increase the of the jets and replace the airfilter to KnN free flow filter or similar type ! find out the maker of exhaust and contact them for info to wot jets required ! could fit a larger fuel feed tap and pipes to help flow of fuel too !
Dec 31, 2013 | 1984 Suzuki Gs 550 L
Pioneer turntable to Pioneer VSX 515 receiver
I'm not sure what you mean by "Wot", but I assume you mean that the receiver doesn't have a phono input, as most receivers now a days don't. You will need a phono preamp. Cost is under $25.00. It provides the amplification to be able to use any high level(CD, DVD, AUX, etc) input as well as the RIAA equalization you need to decode the record correctly. For more information, please visit my website at audioserviceclinic.com. Thank you.
Nov 12, 2013 | Pioneer PL-990 Turntable
Phone lock wots wrong
Ask your mate ... or ... tru the last 4 digits of the phone number. If this doens't pan out, contact your service provider.
Good luck ...
a
Dec 08, 2009 | Samsung M8800 Pixon - Unlocked QuadBand...
Ive just bought a wr 250 but im not sure wot yr i think it could be a 88 model could any 1 help me find out wot yr it is where a good husky wreckers r ?
Find the frame number then call a dealer. They can tell you what year and model bike you have from the number.
Could you take a moment and rate my answer? Thanks!
Sep 29, 2009 | 2002 Husqvarna WR 250
My tabletop juke box wont work know power at all
can you please clarify a bit more about whats wrong with it possibly anything else....if you can change a fuse...chances are you can fix it and i can walk you through it.....just need more info thanks,ben
Aug 13, 2009 | Audio Players & Recorders
Stagger/stammer/flat spot when going to WOT
The slide needle setting is probably to blame. Move the needle clip one notch lower. This will feed more fuel sooner to better match the in-rush of air from the rising slide. Also be sure the carb and carb manifold bolts are tight.
Carb modifications keep the designers employed.
Pleas rate this answer. Thanks!
Apr 06, 2009 | 2005 Yamaha WR 450 F
Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
Apr 11, 2008 | Bosch Washing Machines
X box 360 mtu failed
First learn how to type so that people can understand what you are saying. Then post the error message that you got and exactly what it's not letting you do.
Jan 01, 2008 | Microsoft Xbox 360 Console
Car stereo wiring
http://www.clarion.com/us/en/MungoBlobs/752/342/VRX755VD-English.pdf
Sep 21, 2007 | Car Audio & Video
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
