Question about Hoover F5891-900 Steam Cleaner
I have a Hoover F5891-900 Cleaner, burning smell in just minutes.
It starts to let off a burning smell just after a couple minutes of turning it on then it starts to smoke out of the two holes on top of the motor housing once I turn it off. I took the motor housing off and the fan seems to run well but the motor gets hot in just a minute or so. Also, when I lifted the motor up I noticed the the plastic bottom where the motor was sitting had been scraped from the piece of metal that rotates with the fan rotation. I've tried cleaning the filter and lubing moving parts. Is this repairable? If not, is it worth replacing the motor and about how much do motors go for? Thanks!
  • Hoover Master
  • 17,115 Answers
Probably not, the coils in the motor might be bad.
Posted on Apr 14, 2017
  • 126 Answers
SOURCE: Hoover WindTunnel Canister: Roller brush motor not turning
These motors have a fuse incorporated in the field winding and it sounds like that blew. These motors sometimes overheat at the front bearing and the bearing will melt into the plastic housing. This will cause the fuse to blow. It sounds like that's your problem. You can remove the motor by removing the three screws on the bottom of the powerhead and then check the front bearing for any bubbling or blistering in the plastic housing. The shaft of the motor should turn easily.
Posted on Jan 27, 2008
SOURCE: brushes do not rotate
Sounds as though your drive belt has come off. Or you have an object stopping the brushes from rotating.
Posted on May 18, 2008
  • 3 Answers
SOURCE: Hoover SteamVac Dual V Carpet Cleaner # F7410-900
Turbine assembly is bad. Get part #23 here http://www.vacuumcleanershop.com/hvrmdlf7205900.htm#B2
Not to bad to put in.
You can also find them on Ebay cheaper.
Posted on Jul 01, 2008
  • 37 Answers
SOURCE: Brushes not rotating on my Hoover Steam Vac Dual
if you cant spin the brush by hand then you have a bad turbine.
Posted on Sep 28, 2008
  • 294 Answers
SOURCE: carpet setting not working
there is a belt in the nozzle that is driven by a small motor in turn will drive the roller when set to carpet. did you completely dis-assemble the nozzle? ie, to remove the roller and clean the endcaps? this would also show the belt. The gear on the motor wears very easily and could also be worn. I would change the nozzle or get a new Flair. new nozzles cost about $25-$30.
Posted on Jan 17, 2009
Motor making grinding noise and burning smell
A bit too late I fear. There is either grit from an overloaded dust bag in the motor or the brushes have worn out. Spares and not expensive.
Jun 10, 2017 | Hoover H3044 FloorMate Hard Floor Cleaner
Hoover carpet cleaning started to smell like it's burning and black chunks of rubber came out
Nan, there's obviously a belt that's shot and needs to be replaced. If it started to smell, then it was probably bound up at some point in it's travel path, that stops it from running and the motor shaft burns it's way through the belt, making the smell.
Nov 03, 2013 | Hoover SteamVac Carpet/Upholstery Deep...
I have a windtunnel vacum cleaner. When I
It might be a slipping rubber belt, is the brush roller moving when you look underneath? If it's a self propelled machine there might be another slipping belt. Friction from fast rubbing rubber can smell like it is burning.
Jan 16, 2010 | Hoover Company Wind Tunnel U53019 Upright...
I was cleaning my carpet using my hoover steamvac ls. I had already changed the water 3 times. The last time, the water ran out and I kept running it for a couple of minutes trying to **** up some of the...
(1) take the tank off and reassemble to assure you sealed to the lower handle.
(2) the water feed has nothing to do with the motor or electrical, purely mechanical.
Hoover web site is free, no cost.
Sep 27, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
A burning smell is coming from my vacuum and it starts to smoke after using it for a couple of minutes
i love those situations... i wish i could be there to help you. anyway, the brushes on the motor could be bad... if the motor gets hot, i wouldn't suggest running it until you fix the motor. click here to check hoover.com for the brushes for the motor.
Apr 05, 2009 | Hoover U5753-900 WindTunnel Bagless...
My Hoover bagless vacuum starts to smell like something's burning
What does it smell like? If it smells like burnt anything-it could be that the fan is broken and lodged in the motor. You can see if the fan is good just by looking into it.
Mar 13, 2009 | Hoover U5753-900 WindTunnel Bagless...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Rubber smell, Hoover
Well it sound like you do need a new belt because of how the smell is you might want to stop using it because the smell comes from the burning and over heated belt my solution would be to get a new belt and that should fix it if you need anything else you know whre to find me.
Jun 30, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover F5891-900 Steam Cleaner Logo
53 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
