Question about LG DLE5977 Electric Dryer
Replacing belt on DLE5977
Where can I find instructions or atleast a diagram of dryer so I can check and possibly replace belt. Starting making noise, sounds like belt is worn and has rotated or is out of alignment on pulleys.
  • Anonymous Mar 29, 2014
    The small pulley belt has worn out on the Beko tumble dryer, I am looking for instructions on how to replace it.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
Quite a job since the back does not come off these units. Will need to do the following: 1. Remove the top (3 screws at back and then slide off). 2. Remove the control panel (1 screw on each backside corner, then pull up and forward to snap it out). 3. Remove the front panel (4 screws at top and 2 screws in front of filter housing, unplug door switch and then lift off). 4. Remove the front bulkehead (4 screws, 1 at each tab). 5. Replace belt and check pulley (idler arm) location. Then do the reverse to reassemble. This may be best left to a pro if you have not done this before.
Posted on Jan 07, 2009
Dryer working but is making a very loud noise and has been for a while
you need to check the motor of the drying box. if the boshing up side and down side have a big play. check one by one and that is the cause of loud noising. replace with desame size. becarefull will you replacing the boshing...
Sep 11, 2015 | Dryers
Dryer is making loud jerking noise
bad or broken belt, not sure if its ever been serviced ?
bad drum bearing, bad drum teflon pads or both possibly
or both possibly or in combination the belt could need replacing
Jan 05, 2015 | Dryers
Dryer makes a squeaking/high pitch rubbing noise
& if your not sure get a service tech so you dont do more damage
Apr 06, 2014 | GE DVLR223 Dryers
LG dryer. the drum will not turn with wet towels in it. When it turns it does so slow and the contents do not tumble but get bundeled up in knots. The belt seems ok, it did make a "squeeky"...
If indeed the belt is OK, with it's grooved side touching the drum, and the belt running in the motor drive pulley (not on the smooth motor shaft), then you most likely need to replace at least one of the four drum support rollers.
Jul 10, 2011 | LG DLE5977 Electric Dryer
Dryer is making a squealing noise when you turn on and it smells like it is overheating. Kinda like a belt rubbing or something.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 18, 2011 | LG DLE5977 Electric Dryer
My Maytag Neptune gas dryer is making a very load squealing sound when in use. Is it possible that I need a new motor? I had a repair man come out and his answer was an entire new motor. The cost of the...
I do not believe the problem is with your motor.
I think it is your drum rollers in need of lubrication or replacement.
Replacing the drum rollers is a LOT CHEAPER than replacing a motor
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 23, 2010 | Maytag Dryers
My LG Front-load dryer is making a loud noise during the drying cycle. If i press on the lower left front panel - the noise is muffled quite a bit. Model # DLE5977
heatman101
gfg
Sep 27, 2010 | LG DLE5977 Electric Dryer
Knocking noise
Replace the roller on the belt tensioner. Also replace the belt for it will be worn also
May 20, 2010 | LG DLE5977 Electric Dryer
My lg dle5977 dryer is making a loud noise, and it seems like the drum is not spinning right. Can anyone give me any suggestions how to fix it?
check the rollers on the inside remove the drum to check also check the tensioner pulley at the same time you do this and inspect the belt
May 05, 2010 | LG DLE5977 Electric Dryer
Making a rumbleing noise
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 18, 2009 | LG DLE5977 Electric Dryer
LG DLE5977 Electric Dryer Logo
272 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
