Question about Nintendo DS Lite Console
New ds lite will not save initial settings
Hi, I have a DS Lite bought in Singapore, brand new boxed & sealed. I've charged up the battery & gone over the start up wizard, name, date time etc, however when you are prompted to re-boot to save the settings, it just returns to the set up screen. Also the touch screen appears to freeze on the date screen? Any suggestions?
  • 1 more comment
  • Anonymous Nov 14, 2008
    Hiya!
    My mums DS does exactly the same ( won't save settings and freezes on date) although my mum's DS has never been dropped and was bought from a shop in England. I've been told it's something to do with the software and can occur when cheats have been used (although this is not the case with my mums. Any help would be greatly appreciated. thanks
  • tswan Dec 04, 2008
    I have the same problem, I save settings and it goes to the settings screen when I reboot. Even when there is a game in it...
  • craiggunter Jan 24, 2009
    ok i have the same problem and would love some help to sort it out i can be contacted at craiggunter05@yahoo.com it wont pass the date settings
  • 644 Answers
Either the battery has stopped functioning properly and needs replacing, or one of the battery terminal connecters has become loose and needs to be replaced with a new battery terminal (as the battery acts as a lithium battery found in a pc to save the bios settings), but they are quite difficult to desolder and reapply, best bet is to probably get another mobo. Touch screen ribbon cable could have worked loose and needs tweaking or the connector is faulty and again needs to be replaced.
Posted on Jan 15, 2010
This happened to me too except I dropped my DS.
I'm interested in possible solutions.
Posted on Oct 07, 2008
DS charging..light stays orange...
It could mean that the Motherboard (Main Circuit) could be damaged or could be a fuse problem as you may have said. Although it actually might be the battery, there's one way to find out, if your friend has a DS Lite, ask them if you could borrow your battery for 2 seconds and put their battery in yours to see if it is the battery, if the same thing happens, its the Motherboard (Main Circuit)
Jul 06, 2013 | Nintendo DS Lite Console
My ds lite has stopped charging. we bought a new
theres problly internal problem! maybe some cable connection inside the system is not working!
Apr 08, 2010 | Nintendo DS Lite Console
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
I have bought a new DS lite and charge it up but
sue it could be the way the battery responds to our power usa puts out 30 v more through the wall then the west
you could buy a american battery its possible that there batteries dont last as long
see if it works
Oct 19, 2009 | Nintendo DS Lite Console
Will not charge
no you just need to go to a store and but a new DS lite battery cell, it comes with the screwdriver necessary for the battery switch
May 05, 2009 | Nintendo DS Lite Console
Ds Lite Will not charge for longer than 5-10 seconds
It might be a defective battery. Try putting the new battery in a DS lite that you know works. If the other DS works with its own battery, but doesn't with with your battery, then your battery is most likely defective.
Or you could take the battery out of a good DS that turns on and can do everything, and put it in your DS. If your DS still doesn't work, even with the other DS's battery, then your DS might be broken.
Dec 19, 2008 | Nintendo DS Lite Console
Charger stuck in ds lite
Gently wiggle the charger from side to side, not too much incase you break the pins. it may be a little stiff to start with. Apply a fair amount of force and have lots of patience : )
Hope this helps,
-Deni-YO
May 16, 2008 | Nintendo DS Console
Ndsl power problem
As Bob (HowlingMad) said, the Ds and Ds Lite will turn off immediately after being turned on if the connection to the top screen is broken.
Check the connections between the screen and Ds, if they look damaged then try replacing the ribbon cable for the top screen (or you may have to replace the whole screen - i'm not sure if it is built together on the Ds Lite). If the connections appear fine then it may be that due to the movement the connector has come out of it's socket/plug (also like Bob said), this is easily fixable if this is the case and would require you to take the casing off your Ds and plug it back in.
Hope this helps
Mowcius
May 07, 2008 | Nintendo DS Lite Console
Please help with nintendo ds lite
Try using the original battery.
Dec 19, 2007 | Nintendo DS Lite Console
Keeps redoing initial set-up
Turn it on, then let the battery die completely, this will take a while but it may work, then charge it fully and see if it works, sometimes new batteries do that sorta thing
Dec 11, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
604 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
