Question about Uniden Mystic VHF / GPS 2-Way Radio
VHF Marine handheld Transcever GPS bad screen
It looks like my LED is cracked, may have been caused by internal heat.
    Scholar:
  • 157 Answers
Hello jmartin1. I need some more info, Mgfr., model & serial#. You maybe able to replace the display yourself. The heat could be caused by no air flow inside unit or dust/corrosion bulidup, mabe solved by cleaning.
Posted on Oct 20, 2008
Need a schematic for a UNIDEN HH979 VHF Marine radio.
Go direct to UNIDEN or a repair statin that services this unit
Oct 15, 2014 | Uniden Hh979 Vhf Marine Handheld Radio...
How do I reset the mmsi number on my MHS235 radio
Go to the boat US website, they have a lot of information there.
Sep 09, 2014 | Uniden MHS235 Submersible Floating VHF...
Gentlemen: I have a vintage 1997 Raytheon marine VHF radio on my 1997 Pursuit, not sure of model number as boat is in storage, but it is pretty basic, along with a full slate of Raytheon electronics of...
Hi Jim
Your VHF lives in a fairly harsh marine environment and you're correct in thinking "tuner cleaner" might be the answer. I believe that your volume control is simply dirty. I would suggest using silicone spray (WARNING- Use ONLY the safe for plastics type.) to clean it. I've had good success just removing the control knob and blasting the pot, working it back and forth. You MIGHT wish to do this with the power off however, unless you have a great set of earplugs.
You mentioned that you have a handheld VHFas well. Any chandlery will carry an adapter (about $10) to let you hook your portable to the big antenna should a problem with your marine VHF arise. We've had the occasion once to have to do this and we were glad we carry the handheld aboard at all times.
Cheers!
Apr 12, 2011 | Raymarine Ray218 Marine Vhf Radio E43032
My uniden ltd 715 receives from my handheld but when I transmit to handheld it just buzzes.
Just to clarify something, you say that your hand-held VHF can receive a clear transmission from the Uniden, now which of the radios are buzzing, the Uniden or the HH?. If it's the hand-held buzzing try transmitting on the low watt on the Uniden, get some distance from the radio, because if the hand-held are to close to the on the Uniden on high watt you will get a buzzing, the signal are overpowering the receiver of the hand-held, try getting the minimum of 30 feet away. Good luck.
Mar 24, 2011 | Uniden Solara DSC VHF Marine Radio
Keyboard lock
not sure which button but there is either a H/L lock button which you need to hold for a few seconds to release keys or it is the power on button has to be held. if you have a key symbol in window try the h/l key
check here for manual
http://www.well.com/user/pk/berkeleydragons/Documents/VHF.pdf
i hope this was useful
Jan 24, 2011 | Standard Horizon Hx270s Handheld Vhf...
Here's a good one for an expert. Our newish coastguard boat fitted with 3 VHF radios - all working correctly, recently had a wireless headset system installed. We get huge amounts of electrical nosie over...
From your info the GND & shield (could be the same) are crossed. or one is open. A shield as in the antenna coax or an isolated ground as in an internal type coax in the interconnect cable of the wireless headset assembly. I suggest doing a 'BOARD WALK' routine, Move the wireless assy from one VHF unit to another, the problem follows-bad head set assy. If not, return to original VHF, problem returns bad internal connection in VHF unit. Please let me know the outcome.
Oct 06, 2010 | Uniden Solara DSC VHF Marine Radio
Uniden VHF Hand held Radio HH940
There are several avenues for you. 1. do a serch on ebay for the battery. 2. try your local two-way dealer or 3. go to Unidens web site.
Pat
Aug 16, 2008 | Uniden HH940P Handheld, programmable...
Radio Communications Logo
101 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
