Question about Hotpoint Washing Machines
Hotpoint washer model #WLW4700TCLAD top loading washer. Old machine, but have never had a problem with it. Water does not stop filling washer when it gets full. I know this is a pressure switch. How do I diagnose the problem? Thanks for your help.
  • TurboII Sep 30, 2008
    I was thinking the same thing. I will check the hose when I get home. Thanks again for your help.
  • 1,462 Answers
Not always the pressure switch itself.
years since i saw one of these machines so just take this as guidence.
remove back panel and pressure switch is i remember on rhs near top - it has a small diameter hose going to it. remove this hose and substitute another hose of the same diameter. put on fill and pressurise the hose by mouth. you should hear a click and the water will stop. this localises the fault. if the water does stop, then the fault is:
split in the small diameter hose.
blockage in the small diameter hose.
blockage in the air chamber - the part the other end of the small hose is connected to
fault is more often one of these three rather than the pressure switch itself
Posted on Sep 29, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
Jul 11, 2013 - Uploaded by
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
The washing machine just stops at the rinse cycle. It does a buzzing humming sound and there is no water coming out. The machine is a concept ll model # CDM 2000 RW 439 top load washer.Thank you
The humming sound i believe is the water valve open and calling for water but for some reason no water is coming to it from the house water supply..check that faucets are open and rubber fill hoses on back of washer arent pinched and restricting water flow into washer
Aug 24, 2011 | Hotpoint Washing Machines
The washer water leval dose not work
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. There is a video at this will walk you thru the inspection and replacement of this part. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Jun 04, 2010 | Hotpoint VBSR3100GWW Top Load Washer
Hotpoint aquarius drum fills to top with water
will it stop when you stop the cycle? if so your pressure switch could be the problem however if that does not stop the water you intake water valve is most likley the problem
Feb 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Drum won't stop filling with water
i think u need a bearing seal to ur washing machine so ur gona need a technician and if its gona coast a lot just change it
May 31, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
Hotpoint topload washing machine won't water won't stop running.
washer top load will not stop filling even when turned off
Dec 01, 2008 | Hotpoint VBSR3100D Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
