Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scanner failure on officejet d series
We have a complete copy,, scanner, print failure...please help!
  • msmaniac May 11, 2010
    Have you performed the printer, scanenr self test from the all-in-one? if this test does not pass, it is possibly a hardware issue. Please refer HP's product manual for Officejet 6110 Allinone on how to perform a selftest on print,scan or fax functions.
    If the hardware test was successful, please post some more information that will be required for troubleshooting.
I need to Know The numbers for my Ink
Posted on Sep 29, 2008
Not printing
When printing from the microsoft word document, make sure the printer selected is right. By that, i mean the default printer selected in the printers icon under the control panel should be HP OfficeJet 6100 series and not HP OfficeJet 6100 fax.
So the reason why this message comes up " scanner failure ". is you are either selecting a wrong printer when printing from microsoft word document or probably the printer port is not selected right.
To check the printer port.
Click on start-->control panel-->printer & faxes-->right click on HP OfficeJet 6100 series--> select properties-->Select the top tab called ports-->
Check the ports selected here.
If you have a USB connected printer it should be your printer model with USB settings.
If you have a wireless connected printer it should be your printer model with wireless settings like IP address.
Apr 29, 2010 | HP OfficeJet 6110 All-In-One InkJet...
"Scaner Failure cannot copy, scan, or send fax" warning from my hp officejet 4300..can you all help my problem thx :D
as this printer is connected through a print server so how can i use the scanner through network
Jan 14, 2010 | HP Officejet 4355 All-In-One InkJet...
Try to copy and get scanner failure motice
scanner failure is a hardawre problem. try to copy again and check if the scanner light is on. once the scanner light is not working then try to return your printer in the store that you have purchased it.
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
I have an HP Office Jet v40. No problems when I
Sannaer glass is dirty: Cleaning the scanner glass and white reference strip Follow the steps below to clean the scanner glass and reference strip: Remove any loose paper debris that may be present.
  1. Carefully clean the white reference strip on the underside of the scanner cover (or top cover) with a clean, lint-free cloth, moistened lightly with isopropyl alcohol. Clean only the white plastic part on the scanner cover.
  2. For those models that have a scanner glass, clean the scanner glass with a lint-free cloth, moistened lightly with glass cleaner. The HP Officejet K series and HP fax 1220 have a scanner opening instead of a scanner glass. Make sure that no debris is in the scanner opening. Use canned air to gently blow dust and debris from the scanner slot.
  3. Replace all removed components and close the unit.
  4. Plug the power cord back in and turn the unit back on.
  5. Make a copy to verify the lines are not present. If lines are still present and there is nothing visible on either the scanner glass or the reference strip, the unit will require service.
Instructions are on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu50325&lc=en&dlc=en&cc=us&product=60630&rule=30380&lang=en
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Un active the fax,scann,copy
This solution is for "older" R-series All-in-One's but it may be your solution as well. You may be experiencing a situation in AllN1's called "SCANNER SYSTEM FAILURE" where the scanner bulb may be weaker than it appears by naked sight and doesn't meet system power requirements to "pass" as good to go and thereby is passing to the printer a failure condition. In the R-Series AllN1's the ultimate solution was a bulb replacement. Which surprisingly is not as intimidating as it may sound if you might want to tackle the problem on a do it yourself basis. I can give you more details if you would like. I think you can respond to this Solution; I am new to this forum. If you can not respond directly my email address is DanDeeCo-Online@att.net.
Mar 02, 2009 | HP Officejet 5610 All-In-One InkJet...
R40 Scanner Failure
Hello I have a little problem my printer print well for scanning it is not tell me what I have to do and the copy too doesn't work properly.
thank you for your help. May God bless you in everything that you udertake in life. keep on
Apr 16, 2008 | HP OfficeJet r40 InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
132 people viewed this question
Ben Johnson
