Question about Whirlpool Washing Machines
Water pump leak - Whirlpool Washing Machines
  • 46 Answers
check and be sure that it is the pump and not a cracked hose if it is the pump then the seal is gone in the pump and the pump will have tobe replaced
cheers grantsreps
Posted on Sep 29, 2008
Water pump leaks out weep hole in water pump when plugged in otherwise doesn't leak! Does this mean water pump seal is out?
Yes. Water pump seal is leaking. The weep hole keeps the water from getting to the bearing in the water pump.
Dec 19, 2016 | Cars & Trucks
Removed thermostat due to over heating, water was not circulating in radiator. but now it is leaking by the water pump
if leaking under water pump its a weep hole or bearing to water pump (pump gone bad) if leaking above where thermostat was gasket leak but if overheating was original problem more than likely water pump was and is your problem
Jul 28, 2015 | 1995 Buick LeSabre
Leaking anti freeze from water pump screw
Most water pumps have a weep hole that leaks when the pump seal is broken. Usually indicates the water pump needs replaced.
Mar 01, 2014 | Dodge Shadow Cars & Trucks
I have a leak in the water pump housing gasket
Do you have a leak at the water pump cover? The water pump? Or the 4 gaskets that seal the water crossover (that the water pump is in) to the cylinder heads?
Mar 31, 2010 | 1998 Oldsmobile Aurora
My 2006 charger 3.5 is leaking coolant but only somtimes is it a sign of water pump malfunction no indications on the gauges but car seems to be running hot
this is most likely the water pump if it is leaking at front of engine, the water pump is under the large timing belt cover and driven by the timing belt, so both are changed at the same time.
Feb 04, 2010 | 2006 Dodge Charger
How do you know if your mazda3 2004 water pump leak
Park your car overnight and put a large white piece of paper underneith your car. In the morning check the paper. If the paper is wet with liquid, you could have a water pump leak.
If the paper has green (in most cases) fluid on it, there is a good chance your vehicle is leaking coolant (sometimes refered to as "water"). In many cases, when you are leaking coolant it could be coming from the water pump.
Grab opposite ends of the water pump pulley and check for "play" (looseness): Try to rock it back and forth. There should be no give. If there is, the bearings are going and it's time to replace the water pump. By the time you can feel play in the water pump pulley, you may also be able to hear the bad bearing when the engine is running - there may be a low-pitched grinding noise coming from the water pump pulley
Visually check the water pump (it's located behind the pulley) for signs of a coolant leak. If the water pump gasket is leaking, it must be replaced. This is a good time to get a new water pump, too, unless it was just recently replaced.
Nov 04, 2009 | 2004 Mazda 3
Coolant leak behind bottom pulley
Could be water pump weephole leak or water pump gasket under water pump trailing down timing cover and exiting behind crank pulley or water . Worse case, leak in timing cover. Water crosses through timing cover to and from water pump to engine block.
Oct 16, 2009 | Nissan Pickup Cars & Trucks
Water leak
sounds like the water pump they leak from the bottom of the pump
Dec 29, 2008 | 1993 Jeep Grand Cherokee
Washing Machines Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal De
