Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Video noise For several months we have experienced video noise on screen--does not matter which signal--directv--dvd or photo memory cards. It is snow like and moves around the screen. Is this something we should have repaired or could it possibly be noise from the power cord--we have an expensive surge protecter connected.
  • 84 Answers
Noise on all inputs ?
do you have these connected via RCA or svideo connections.
If you can use the digital inputs hdmi
Here are some other ideas
inplug all your inputs and see if you still have the noise bars
if you do try unplugging any device in the same circuit
do them one at a time to see if you can find the unit causing the noise
be sure and have all of your power and input cables away from each other where they do crosss try to get the junctions as close to 90 degrees as possible
Posted on Sep 29, 2008
Why can't I access my photos on my computer from sony memory stick pro duo 4GB but can view on camera?
You may be able to get the images from the card. try using a program called BadCopy Pro. I used it a few times to get back images from memory cards that would not work on any computer. Good Luck.
Jun 01, 2014 | Sony 4GB Memory Stick PRO Duo Memory Card
How to extract my photos from 420 to my laptop w7?
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer.
Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
May 18, 2013 | Logitech ClickSmart 420 Digital Camera
Scheduled a timer recording of a program on a DVD+R and when I went to play it back all I got on the screen was noise and snow. I now realize that I used the wrong disc (should have used only DVD-R). ...
Hi,During timer recording adjustment you must have selected what ever you want to record..i.e: Tuner Channel , or ,Video1 input ,or Video 2 input etc..This problem is related with Source selection but not with - + type Disc..wrong disc will refuse to record at the beginning..
The noise and snow shows that your recorder was Recorded an unadjusted RF channel..thus no TV signal was available during recording ..
I assume that your DVD recorder has built in TV tuner in...To correct the problem,first you make an automatic Ch set up ,search the available channels either on the Cable (if you have ) or RF local channels thru Arial Antenna..
than you try to record again by carefully selecting will record TV RF channels successfully. Or you can attach another video source to your Recorder thru the RCA cables on the back panel and by selecting the respective SOURCE in accordance withe cabling you have made than you will record the AV signals available on your Receiver..
If you need more help pls let me know for further advise.
Aug 10, 2011 | Toshiba DVD Recorder
PNY optima sd card "card error"
You should try some photo recovery software to rescue the files on your camera card, here are some you may rely on. Both programs can also recover videos and music.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures are recovered, do not attempt to save more files to the card in case the original files(your pictures) are overwritten.
Jun 15, 2009 | PNY 4GB Secure Digital High Capacity...
[ ] Please copy this web page link and paste it into the address bar of your web browser. It will take you to the Direct Tv troubleshooting page. On this page you will find a list of problems with solutions. You will also find a list of extensions in the list. The extensions are also troubleshooting problems that you can sort through and find the problems that is most like the problem you are having. There are suggestions for solving the problems and telephone numbers to help you, if you cannot solve the problem yourself. I am sure you will find help with your problem on this page. Thank you for using FixYa and have a nice day.
Mar 03, 2009 | RCA DIRECTV Satellite Remote Control
Sungale digital photo album TD350A
After playing with mine for awhile, I found that you can insert your memory card into the album, click "exit" until you get to the photo icon, click it, then it will give you a choice of "internal memory" or Memory card," click mem card. You can use the right and left arrows to scroll through the photos (time consuming), then when you see one you want to download, hit "OK" to pause it, then click the up arrow, it should say "saving..." hope this helps.
Nov 26, 2008 | Sungale PD-701
There is a fault in the main processor that is causing noise. The set will have to be serviced. The tech will probably try the main video processing board to start.
Jerry G.
May 13, 2008 | LG 42PX5D 42 in. Plasma HDTV
Noisy lines in photos
You may have a problem with your lens unit.
Sep 30, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
