Question about Panasonic Televison & Video
My Panasonic DVD Recorder DMR-EH60DEBS S/N VQ5HD001079 has stopped working. Having done some tests, the hard disk is not functioning. I think there may be some software or operating system installed on the hard disk. Is it possible to purchase a new hard disk with the necessary software/op system already installed on it? The faulty disk is a Samsung 200 GB type HA200JC
Palmbeach
  • 185 Answers
SOURCE: AELFCHECK Problem with Panasonic DVD Recorder
Hi
This problem is associated with a regulator on the power board. It's an easy fix if you can use a soldering iron.
If not you may be able to get someone to repair it for you. I have posted instructions on how to replace the defective component.
Please note the instructions I have given refer to the DMR E55 but the E95H is much the same.
To see my earlier posting, please Click >HERE<
Posted on Mar 13, 2008
marked
  • 6487 Answers
SOURCE: where can I obtain a
Check this link for the terms and conditions about the replacement http://panasonic.com.au/content/library/files/F000536.pdf
Hope that helps........
Posted on Jul 01, 2008
rizla
  • 1463 Answers
SOURCE: Panasonic dmr-eh57 multi-region unlock code
see this any luck here dvd
riz.
Posted on Aug 01, 2008
SOURCE: I have a Panasonic DMR-ES30VEB.
Are you playing it through the vhs mode. It will not play through the dvd mode via 'TJ' or dubbing as the dvd record function is macrovision protected
regards
snapper
Posted on Dec 09, 2008
SOURCE: Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
How do I stop my Panasonic DMR-EH75V DVD Recorder from automatically turnig itself off after 75 seconds?
It could be overheating.. Is it fairly consistent at 75 seconds? To test put the unit in the fridge for 30 minutes then quickly connect it up and test. If it is longer then 75 seconds then something is getting to hot. I've put hard drives (especially laptop ones) in the freezer if I need to copy off data but it clicks/stops working at room temp.
Aug 10, 2014 | Panasonic Diga DMR-EH75V DVD...
I have a Panasonic DMR ES30V DVD/VHS recorder. Sometimes the DVD recorder will stop (generally in the first 30 seconds) and a Check light will show. I then have to shut down the unit and restart. ...
I had the same problem with my DMR-E30VS. I tried a disk cleaner, that did not work. I took the cover off cleaned the lens witk a Q-tip and Isopropyl (rubbing) alcohol. It works fine now!
Jun 28, 2011 | Panasonic DMR-ES30VS DVD Recorder/VCR
My DMR_E80H recorder does not read blank dvd-r disks
I don't have a solution but I am having the same problem (same model DMR-E80H). It will read finalized dvds but won't recognize or play blank or non-finalized dvds. About a year ago I had to replace the hard drive . . . I'm just assuming that the dvd recorder is just slowly breaking down and will need some kind of repair of certain components. (I think we bought it new in 2003/2004?)
Feb 13, 2011 | Panasonic DMR-E80H DVD Recorder
Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Feb 07, 2010 | Panasonic Televison & Video
How to transfer Panasonic DMR-E80H recorded DVDs to computer
I have to agree with XELIAM regarding finishing the disk, under the DVD "FUNCTIONS" selection from the remote. I also use the SLYSOFT products to transfer my videos to what ever other mode of video I wish to have, whether iPOD (MP4), or DIVX (AVI) or loads of other options. Slysoft makes a GREAT product
Dec 04, 2009 | Panasonic DMR-E80H DVD Recorder
The remote can perform some functions but not others - left and up arrows work occasionally. Makes it hard to program or to delete, or even scroll.
try opening your remote.clean it with alcohol and soft cloth.let it dry.while drying, check the rubber buttons for breakage.assemble and test all.
May 28, 2009 | Panasonic DMR-EH55 DVD Recorder/HDD...
Recording from hard disk to dvd
Must be a trick question... it has a recordable drive.
No to DVDs, Yes to DVD-R, DVD RAM, DVDDL
Dec 03, 2008 | Panasonic DMR-E55 DVD Recorder
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Sep 22, 2008 | Panasonic DMR-EH65 DVD Recorder/HDD...
Panasonic dvd recorder
disk came off of the tray inside. unplug and open it maually.
Dec 03, 2007 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
