Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
HOTPOINT WD72 ERROR CODE 31
COULD YOU TELL ME WHAT THE PROBLEM IS
  • 750 Answers
Hello mazsmith,
Welcome to fixya,
You said, COULD YOU TELL ME WHAT THE PROBLEM IS ?
E31= Motor Drive Problem -
Run the programme again,
if problem persists call for
a Service Engineer.
I will tell you a secret.
Try unplugging the washer for 5 minutes and then we will see if this has reset the system!
like rebooting your computer.Some times it is only a glitch and no mechanical problems are there!
If so you saved a service call.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Thank you.
Waiting for your results!
Posted on Oct 17, 2008
Error code F31 on hotpoint wd72
I find no F codes for it only E 30 or 31 means motor failure and call service
Mar 18, 2015 | Hotpoint Washing Machines
Error code F-05 showing on my Hotpoint ultima
Error code F02 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose from bottom of drum.
Remove and clean filter inside hose.
Remove hose on to pump and check for blockage or obstruction here as well.
Pleas rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WD72 Front Load...
Error message 31
Error 31 : you need to re-boot system do this by unpluging from wall leave for 5 min plug in and then switch on again this often is enough to re-boot, as it is normaly just a glitch and not a mechanical problem
Jan 10, 2010 | Hotpoint Ultima WD72 Front Load...
Error 16 on hotpoint wd71 n what does it mean???
F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer
Mar 12, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Thanks for using Fixya.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WD71s
The e30 error code relates to motor drive problem. Open the service panel and look for a broken belt and does the motor spins. Let me know with your results if you will need for further assistance. Good luck!
Sep 08, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
138 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
