Question about Vivitar Super Wide Angle 19mm f/3.8 Manual Focus Lens for Canon FD
I have a 20 mm Vivitar for Nikon, the mount wobbles, I need a dwg to tighten the mount
Need to convert a Vivitar 70-150mm telephoto from Canon TX to Nikon FTn mounts
Vivitar made several different 70-150mm lenses. If the lens has a T-mount then you can purchase a Nikon T-mount adapter and replace the Canon one on the lens. If the lens does not have a T-mount then you're out of luck. Nikon cameras have thicker bodies than Canon cameras, and an adapter would have to have negative physical size.
Mar 16, 2014 | Vivitar Series-1 3.5x Tele Conversion...
Can I use Vivitar Mc 50mm F1.7 Lens on Nikon D3200 ?
Vivitar makes lenses with a variety of lens mounts to fit different brands of cameras. If the lens has a Nikon mount then it will work on the D3200. If it has some other mount then it will not work.
Feb 27, 2014 | Vivitar Pentax Mc 50mm F1.7 Lens Pk...
Does vivitar 100-300 lens mount on nikon d3200
Vivitar makes lenses with a variety of lens mounts. If the lens has a Nikon mount then it will mount onto a D3200. If has another mount, then it will not.
Feb 12, 2014 | Vivitar Cameras
I am thinking of using Vivitar Series One 28-300mm f/4.0-6.3 Auto Focus for Nikon D2x...! Does this have aimage stabilisation motor in it?? Do u recommend this for the camera??
I don't think it has image stabilization. If you use a tripod, stabilization is not important. If not, you can increase your shutter speed to compensate. Vivitar makes fair quality lenses, but you have a Nikon. I presume that you bought your Nikon because you want top quality images. If it is a matter of money, I would wait until I could afford a Nikon lens. As an alternative, consider used Nikon lenses. I generally carry a 10-24 mm DX, 28-105mm and 70-300 mm and a 60mm macro when I travel and it works well.
Sep 20, 2013 | Nikon D200 Body Only Digital Camera
85mm 1.4 is not metering exposure on my nikon d7000
It is a manual focus lens. That is for sure. The D7000 only can meter, when a lens is fitted with a chip. Usually the Nikon AF lenses. (other brands like Sigma that are compatible) To my knowledge the Vivitar is not. You only can use this lens in Aperture-priority and manual exposure. See a discussion on Nikon forum about this lens, that is capable of shooting brilliant pictures.
Link to Nikon cafe forum about Vivitar 85 mm
Aug 29, 2013 | Vivitar Cameras
Will an auto focus Vivitar Series 1 100-400mm work on a nikon d80
Vivitar Series 1 lenses were available with a variety of lens mounts for different camera makes. If the lens has a Nikon mount then it will work on a Nikon D80. If it has some other mount then it will not fit.
Nov 05, 2012 | Vivitar 100-400mm f/4.5-6.7 Series 1 Lens...
Vivitar screw mount lens, Nikon D-80 camera. Is there an adapter for this?
The M42 mount was used by several camera manufacturers, most notably Pentax. Nikon is not one of them.
Vivitar made many lenses with a T-mount. This consists of a screw mount on the lens and a suitable adapter, depending on the camera body. This allows a lens to be used with different cameras simply by changing the adapter.
If your lenses are T-mount, then yes, there are adapters available. One source is here.
Be aware that you'll probably lose any metering capability when using any lens with this adapter. You'll have to use a separate light meter or else view the resulting picture on the display and adjust the exposure appropriately.
Dec 22, 2011 | Nikon D80 Digital Camera
Will the Vivitar SI 70-210 mount on my Nikon D90. Will the AF work properly? Thanks
Vivitar makes lenses for a variety of cameras, so a lens for a Canon, for example, will not fit onto a Nikon. Assuming the Vivitar lens has a Nikon mount, then yes, it will mount on the D90 and yes, it will autofocus properly on the D90.
Jan 21, 2011 | Vivitar 70-210mm f/2.8-4 for Nikon AFD
Can a nikon FSA L1 work with this?
hi there, your Nikon certainly will work with this telescope, but `you`ll need a T-ring adapter that adapt the lens mount on the camera body with the viewfinder on the telescope
hope this post will help
Jan 05, 2011 | Nikon Sky & Earth 7452 (20-60x80 mm)
it depends what mount your vivitar lenses have - you can easily search ebay for mount adaptors that will allow you to use most older lenses on the 4/3 body, but you will only be able to use manual focus and need to work in aperature priority or fully manual mode. A generic adaptor for a OM, Nikon, Pentax or Contax mount should cost around $20. you should read up on them as there are some differences with how they are made and function, but basically are just mechanical coupling devices that fit the lense to the camera. remember, you lose all automatic features
Dec 18, 2008 | Vivitar Cameras
Vivitar Super Wide Angle 19mm f/3.8 Manual Focus Lens for Canon FD Logo
75 people viewed this question
Top Vivitar Cameras Experts
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
