Question about Canon 3045 Black and White Copier
Canon 3045 Copier
Where is the setting to change the copier tray assignments?
  • SHADOW CONAN Feb 16, 2009
    MY COMMENT IS E000805-0000
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Tray priority or size ?????
size is in the tray itself. Depending on the settings it reads the manual adjustments.
priority is in the menu settings
Posted on Sep 29, 2008
How do i fix canon ir5075 copier tray 2 that is not working
Not sure what you mean by not working, inside the tray for paper size adjustment. Make sure that tray is adjust correctly. If one of the clips brakes off you might need a new tray.
Changing Paper Tray Size
May 09, 2015 | Canon Imagerunner 5075 Digital Copier
Canon ir 3045 error code E00002 0000
CANON IR 3045 ERROR CODE E000002-000, plz urgent rply solution
Dec 01, 2011 | Canon iR 2016i Black and White Copier
@How do I rest the admin password for Canon if 3045
press additional funtions, 2 and 8 simultaneously, additional functions, copier, function, clear, password, ok. then turn off and on again with switch on the side of copier.
May 16, 2011 | Canon Office Equipment & Supplies
Ir4570 message: finisher cannot be used help me pls.
Dear colleagues,
I have Canon IR 3045, is giving the following message "finisher cannot be used" is there any solution to reset the message.
Many thanks for any assistance.
Boualem
uae
Sep 16, 2010 | Canon ImageRUNNER 3570 Copier/Printer
I cannot clear an error message #2 on the screen and it has locked up my printer.
do you mean error code E002-000?
If thats the case, follow the procedure:
press*
press2
press8
press*
select COPIER
select FUNCTION
select CLEAR
select ERR
select OK
turn off and on
If these doesnt resett your machine, you need to change fixing heater ceramics.
Hope that helps!
Aug 28, 2010 | Canon 3045 Black and White Copier
How to copy a booklet on the canon 3045
To make a stapled or folded booklet on the 3045 will require the "Saddle Finisher option. This is a finisher the attaches to the left side of the copier. It has 2 trays and an additional tray on the very bottom of the finisher. If you do not have this it will be impossible to make a booklet that is two sided with the pages properly sequenced. If you have the saddle finisher attached. On the screen select special features and on the first or second screen you will see a booklet button, press that and follow the prompts. If the booklet button is greyed out you do not have the Saddle Finisher.
May 18, 2010 | Office Equipment & Supplies
I have an old Canon 1150 color copier. The bottom drawer #2 dropped and can't feed paper properly. So I put 11x17 paper in drawer #1 which had 8x10 paper originally. Now the panel still shows drawer #1...
Is there a paper selection wheel or bar in the tray?
Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
Dec 03, 2009 | Canon CLC 1150 Color Copier
ImageRunner 1023N.. assign IP
Press the additional funktion buton,press the arrow keys until 9 system settings is displayed press ok press the arrow again until 5 neywork settings is displayed press ok.TCP/IP settings will be displayed press ok and change the ip to your network adminatrators specifications.
Aug 17, 2009 | Canon imageRUNNER 1023 Black and White...
Imagerunner 1023if How do I change paper size on printer
you need to change the paper size on the copier or the paper tray dial.you can also select a paper tray from the printer menu..Alt set the printer properties to a paper tray with legal paper and it should overide the setting
Aug 10, 2009 | Canon imageRUNNER 1023iF Black and White...
Canon 3045 Black and White Copier Logo
227 people viewed this question
old marine
old marine
