Question about Lexmark Wheelwriter 1500 Typewriter
Lexmark 1500 typeover
Hi , I have a lexmark 1500, which intermittanly types over previous letters. I have oiled the print assembly slide bar and have replaced the type wheel. Neither have helped. With the power off, the print assembly slides easily with no binding....? Any suggestions appreciated, Thanks
  • Lexmark Master
  • 3,594 Answers
There are a few possibilities, first check to see if it is in the language mode, light on the rt. side code "L" will get you out of it. If that is OK the keyboard may be selecting the wrong keyboard. Press and hold code key, press and release the "L" key, type 001, release the code key. If this solves the problem. check the keyboard connectors. If they seem to be fully plugged in you will need a keyboard.
DickyO
Posted on Sep 29, 2008
P4350
The carrier slides back and forth on a bar that must slide smoothly. When you open the printer up, the heads come to the center for cartridge removal, so that part of the bar is oiled. Try lightly spraying a silicone or Teflon spray or a drop of high quality machine oil to the bar where the head will go through it, smearing it along the the bar. Another part is the plastic belt with teeth on it that moves the head from side to side. If the teeth have broken off, the head won't move properly. Some of these printers have an entire head assembly where the cartridges set that can be removed after the cartridges are out. If this print head assembly is damaged or worn out you will also get the error. The head damage is usually because some one yanked jammed paper vigorously out, pushing the head out of position, or the print head was moving when something stopped the head.
Aug 18, 2014 | Lexmark P4350 All-In-One InkJet Printer
I have a Lexmark x7350 connected to a PC running Win7. I have previously been able to print with this combo with no problems at all. I have removed the device, uninstalled the Lexmark software, rebooted,...
Please follow the steps on to properly Uninstall Lexmark Printers from your computer. After the uninstallation process is done, reboot pc when prompted.
When pc turns on, check if your Windows 7 is running on 32-bit or 64-bit. On your computer, go to Start menu > right-click on Computer > Properties. Take note of the System Type.
Use the link below to download and install the Lexmark X7350 Printer Driver on your computer. Note: Use the Vista Driver on Windows 7. - Lexmark X7350 Driver for Vista 32-bit - Lexmark X7350 Driver for Vista 64-bit
When the installation process is successful, try to print a document to verify that the problem is fixed.
Sep 11, 2011 | Lexmark X7350 All-In-One InkJet Printer
Lexmark t614 manual feed how it works
  1. Push the lower release latch. The multipurpose feeder door drops open.
  2. Pull out the metal bar in the recessed area on the multipurpose feeder, far enough to accommodate the paper you will be using.
  3. Slide the paper width guide to the far right.
  4. Prepare the print material for loading:
      • Flex paper or fan envelopes back and forth. Do not fold or crease the paper. Straighten the edges on a level surface.
      • Hold transparencies by the edges and avoid touching the print side.
      • Fan the stack of transparencies to prevent jams.
      • Be careful not to scratch or leave fingerprints on the transparencies.
  5. Use the stack height limiter as a guide for stack height when loading print materials.
  6. Load one type of print material in the multipurpose feeder. Do not mix types.
  7. Slide the paper width guide over until it fits snugly against the side of the print material.
If you need further assistance please contact Lexmark Technical Support.
Aug 24, 2011 | Lexmark Optra T610 Laser Printer
I have a Lexmark 1000 Personal Wheelwriter and the daisy wheel does not easily slide into place. It then just keeps turning until the machine beeps and it stops. Will not type of course. Is there a...
No, the printwheels are the same for all Wheelwriters. Make sure the letters face the roller when you put it in (pull the print hammer assy back and check for paper clips, ribbon pieces, etc. first).
Jan 02, 2011 | Lexmark Wheelwriter 1500 Typewriter
How do I make it silent when typing ?
The 1500 does not have a delay print mode. You press the key it types the letter.
DickyO
Dec 22, 2010 | Lexmark Wheelwriter 1500 Typewriter
IBM Wheelwriter 1500 When I'm typing, only the
The platen has probably worked itself loose. Press down firmly on both ends of the roll it should snap into place.
DickyO
Oct 27, 2010 | Lexmark Wheelwriter 1500 Typewriter
Changed print wheel (same type as previous) now typing letters incorrectly
Check the "Pitch" selector slide switch on the lhs of the keyboard... it should be on 10, 12 etc position to match the printwheel... NOT in the PS position.
Sep 23, 2010 | Olympia Mastertype 3 Typewriter
Wheelwriter 3 Selector Assembly
The selection motor bearings just right of the print solenoid get dry a little WD40 on the front and rear bearings usually takes care or this.
DickyO
Dec 14, 2009 | Lexmark Wheelwriter 3 Typewriter
Lexmark Z2420: How to nudge margins to align a form
Go into your printer software before printing, tell the software what you are printing on letter, 4x6 labels etc.... then print
Jul 08, 2009 | Lexmark Z2420 Printer
Erronous letters or numbers
Under the ribbon there is a motor that drives the print wheel try to get some light oil on the front and rear bearings (wd 40 usally works well) its a little hard to get to the rear one.
hope this helps
DickyO
Jan 29, 2008 | Lexmark Wheelwriter 1000 Typewriter
Lexmark Wheelwriter 1500 Typewriter Logo
55 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
