Question about Kenmore 659 Electric Dryer
No heat, timer is working and the start button
The start button need to use hand or thing to keep pushing it then dryer is running.
Even though the dryer is running, but no heat and the timer is no timing at all.
Thanks.
  • 1 more comment
  • Michelle_wpa Sep 30, 2008
    Ser Mp 2205335
    Type: DDOT-ELE-2406028-EH54
    Thanks.
  • jwoodring7 Jan 30, 2009
    I have the same problem you have keep the start button pushed in if you let go the dryer stops running and if you hold it in with something the timer does not work and the unit does not heat.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Please post back with your COMPLETE model number (located around the door opening if this is, indeed, is a Kenmore), so that I may be able to do some research to determine what may be causing your problem. All dryers are not contructed the same as models differ in features. Thank you.
  • 5,911 Answers
I need your MODEL number. You've given me the serial number and the type of dryer. I need the model number in order to cross reference. If this is a Kenmore, the model number should start with "110." followed by about 8 numbers. I apologize for requests for repeated information, but I cannot verify your information without it.
Also, I'm a bit miffed about the symptoms you describe. You said the dryer is running, but doesn't heat. Is that correct? If so, the following link will give you some insight on WHAT components can cause a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Most dryer no heat problems are caused by improper air flow due to lack of proper maintenance. It is very important to keep the exhaust vents free of lint accumulations, rodent infestations, kinks and bends. Simply cleaning the lint trap is not enough. You have to inspect the vent ducting to ensure it is free of obstructions. The rule of thumb when it comes to ventilation is: the SHORTER and STRAIGHTER the exhaust vent, the BETTER. Every bend, kink or sag can cause potential choke points for lint to accumulate. It also creates resistance against the blower motor and forces it to work harder. This will actually cause the dryer to OVERHEAT to the point of failure. It is also recommended that you use the metal semi-rigid type ducting instead of plastic. It is more heat resistant, resists rodents chewing through it (mice love lint for nesting), and resists crushing.
More commonly, the thermal cut-out (also known as a thermister on some dryer models) will blow as it is designed to do. Once this component goes bad, it must be replaced. The reason I mention all these preventive measures is because most people simply do not know, and if you simply replace bad components and don't verify the ventilation, you may have to replace the same components again - real soon. Also, leaving a dryer with dirty ventilation creates a potential fire hazard.
As far as the timer is concerned, this may just be a symptom of your no heat problem. A lot depends on how the dryer is wired. I think we need first need to resolve the no heat problem, before assuming a timer problem. Please let me know some more information about your dryer, so I may give you a more definite solution. I hope that I have been of some help so far.
Posted on Sep 30, 2008
My dryer doesnt go on. The front panel still clicks and when i push start button it buzzes but doesnt go
Belt, fuse, door switch, timer switch, something caught on the drum (all sorts of things get caught back there), heat sensor (depending on the age, had one that had a heat sensor would turn the dryer off, if told the computer dryer was overheating even though had not been running), bad motor, bad motherboard for dryer (again depending on age of dryer)
Jan 06, 2015 | Dryers
No heat and timer keeps running
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 16, 2011 | Roper Dryers
heatman101
Dec 17, 2010 | Roper Dryers
I have a LGR5636EQ3 Maytag dryer that will not heat up and the timer is not keeping correct time. Dryer will run but longer than preset time and no heat. No click noise when started. I had dryer set at 60...
heatman101
Oct 13, 2010 | Kenmore 73952 Gas Dryer
The dryer runs but no heat. The igniter glows when you start the dryer for about 10-20 seconds then goes out but the gas never ignites. I have tried bypassing the high limit fuse in the vent and have...
heatman101
Sep 11, 2010 | Roper RGX4634KQ Gas Dryer
Dryer start button doesn't work
door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Jul 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
No heat
You may need a new heating unit for your dryer, but usually and most always it's the temperature sensor that needs reset, most of them have a push button built into the sensor that you can push to reset it.
This most always works, failing that you need a new element to heat. though sometimes wires rattle loose and simply need plugged back into socket.
In all examples you need to take the panels off your unit to get the parts in question.
Hope this helps.
Jan 01, 2010 | Dryers
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
90 series will not stay running or heat
DO NOT KEEP THE BUTTON PUSHED IN AND RUN IT...It's the motor relay and the even heat board in the console. By keeping the button in, you're bypasssing a safety feature and could cause fire. It won't heat like that anyway. Repl. the relay witht the small blue wires and the board in the console and you should be fine.
Jan 30, 2009 | Kenmore 659 Electric Dryer
Whirlpool dryer will not stay on, no heat, and timer acts weird
sounds like the motor or the even heat board is out i would say the even heat board is more likely
Dec 09, 2008 | Kenmore 62602 Electric Dryer
Kenmore 659 Electric Dryer Logo
87 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
