Garage door locks?
I'm unable to unlock the garage door with my car remote. I have to go through the house and open the garage with the device inside the garage. How do I unlock it?
I finally held the lock button down and it seems to be working now. Keep your fingers crossed!!
Posted on Sep 30, 2008
Is there a way to unlock the rear door of a 2004 jeep liberty from the inside
If you hit the unlock button in the door 2 times, it should unlock the tailgate. Otherwise you may have to go back to the dealership and have them program a new remote for you. If the battery in your remote went dead, it may work again by replacing the battery.
Jul 11, 2014 | 2005 Jeep Liberty
(Chamberlain 1/2 hp Whisper Drive garage door opener) the garage mounted opener will open the door, but none of the remotes now work. batteries have been changed already. Is there a way to reprogram the...
If the wall button will operate the door up but none of the devices do then look at the wall button. Find the lock button and push it for 2 seconds and then try the remotes again. This is your vacation lock. You can get a manual at chamberlain.com. Now if the door does not open or close with the remotes you can reprogram them. Press the colored learn button on the motor head and then press the button on the remote. Repeat for each remote. If they fail to program you will need a new logic board. Thanks BB
Aug 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Unable to open the garage door with the remotes. I closed the door from inside unit and came out. but later on when i tried opening it from the remote there is nothing happening. Please please help me. My...
It sounds like your remote may have deaad battery OR got de-programmed. I hope you have another door into the garage. You NEVER should rely on a radio remote as the ONLY access to the garage! Many failures can happen to prevent the remote from working.
IF you can kill the power to the opener in the garage, do that for a couple minutes then repower and try again...
And for goodness sakes cut in a new door as EVEN in a condition where the power fails in a disaster you want to have access to your vehicle... this is a "wake up call" for you! There is also a keyed lock that can give you access to the manual trip cord to allow manual opening of the door.
Jan 09, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door remotes do not work. 139.663953
On the rear of your motor unit near where all those white wires go you will find the smart/learn button. Hold the button down on your remote and press and immediately release the smart/learn button. Do this with all your remotes.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote
It sounds like the lock function has been toggled on. Press and hold the button on the wall control with the lock icon for 3 seconds. This will toggle that function off.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener willnot work inside trailblazer .
Do you have a antenna build into the windshield of your car? If so thats your problem and there not much you can do about it other then stick your hand out the window when you pull up, and point the wire coming from your opener toward the door itself. Do not cut or add to that wire.
Jan 31, 2009 | Chamberlain Powerdrive PD422D 1/2 HP...
Remote does not open garage door
It sounds like the wall button has the lock feature engauged.
Is there a small green LED flashing inside the wall button?
Push and hold the lock button for about two seconds and the LED should stop flashing. This will unlock the garage door opener and your remotes should start working. You may have to reprogram your remotes and homelink again since you triedprograming in the lock mode.
Good luck.
Jan 20, 2009 | Chamberlain 950CB Remote Control
Neither remote control will open door but wall mounted button wil
Make sure the code set inside the remote is the same as in the main reciving unit code.
Dec 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Central locking keeps locking the car. Unable to open drivers side door
Hello, we have a 2003 Kia Rio- problem as above- unlocking and then locking- only way in and out through passenger door.
This is what I have done and everything is back to normal- I hope it works for you.
1 Remove 25AMP fuse that controls door central locking from main box under the bonnet.
(AT this stage my passenger door opens- drivers side does not, the mechanism won't fully rotate)
2, Spray key with WD40 (or similar moisture repellent lubricant). Gently turn key to loosen mechanism- Partly remove key and spray lubricant into lock, have fun locking and unlocking!
3, Replace 25 amp fuse
4, Write yourself a cheque for garage labour and parts and wife brownie points!
Aug 09, 2008 | Kia Rio Cars & Trucks
Computers & Internet Logo
203 people viewed this question
David Payne
David Payne
