Question about Lexmark X4270 All-In-One InkJet Printer
Lexmark X 4270 fax, copy, scan machine
When I send faxes everthing works right. When I try to make copies of something the copy comes out blank. What do I Need to do?
  • Anonymous Oct 03, 2008
    not printed
  • dester Feb 02, 2009
    I want to know can you scan a plastic drivers licenes on this home scanner
5 Suggested Answers
SOURCE: need help on my lexmark x 4270
If you are with a lexmark printer switch to windows xp or just try to buy another printer... If you are using this x4270 printer probably it is famous for faxing problems so probably you must not try to fax...Try lexexpress if you are in warranty
Posted on Jan 13, 2008
SOURCE: SCAN,COPY,FAX PROBLEM
unable to scan,copy or send a fax.I can copy from desktop help R.FARDA
Posted on May 16, 2008
  • 1218 Answers
SOURCE: Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
Posted on Aug 23, 2010
I need to know how to remove my info from my lexmark 4270 series before I trade it in.
1.Disconnect the power cable from the back of the printer.
2. Hold down the Stop/Clear button. (To the right of the Black Copy button.)
3.While keeping the button pressed down, reconnect the power cable. A message on the LCD will display MEMORY CLEARING.
Note: The Fax, Copy and Scan buttons will remain ON until the message disappears. Only the Fax button should be ON when the function is complete.
Thanks for using Fixya.
Feb 27, 2011 | Lexmark X4270 All-In-One InkJet Printer
I have a lexmark all-in-one printer, model # x4270, when I fax someone, when received, the fax is a blank sheet of paper?
try and make a copy with the fax... if it comes out the same way... turn the paper face up if it was face down or vice versa and try again... if it works then fax the same way and see what happens... if all goes well then keep copying and faxing that way... if that works but fax does not work... print an internal report... if that does not print then you have main board problems... if internal prints print then you have a problem with your ccd... thats a big long strip that rests right under the keyboard... thats what does the scanning... if that is bad... then when you fax... or copy it will be blank or black... depending on what is blown on it...
Dec 27, 2009 | Lexmark X4270 All-In-One InkJet Printer
Remote fax error when sending a fax
Does it only happen going to one certain fax destination or every destination? There are some things to try on the Lexmark web site.
Go to www.lexmark.com and click Support->Technical Support. Type in 4270 in the 'Search by Model' box. Type in 'Remote fax error' in the 'Search the Knowledgebase' box. There is a topic called 'Problems Sending a Fax to Specific Fax Machines' that has some good general tips.
Steve
Feb 26, 2009 | Lexmark X4270 All-In-One InkJet Printer
Need help on lexmark x 4270
To whiom it may concern my printer wont allow me to fax or copy do to it saying paper jam,so I cleared the jam and made sure that nothing is in it but it keep saying paper jam and will not allow me to fax or copy. Can you kindly help me with this problem please.
Oct 28, 2008 | Lexmark X4270 All-In-One InkJet Printer
Lexmark 8300 print/scan/fax
There are sensors in the document feeder that detect the width and length of the paper being copied or faxed. Try getting a can of compressed air and go nuts blowing all the dust out of the feeder, if you spray everything you can get to, you will probably blow clean the sensors. Just an educated guess.
Good luck,
Printdoctor
Jun 19, 2008 | Lexmark X8350 All-In-One InkJet Printer
TX problem
If I understand you right, what you send, people are receiving blank sheets?
When you try to run a copy are those blank also?
If so your problem is with the scanner. The drum should have nothing to do with sent faxes.
Unless your putting the paper in the scanner upside down. And if you ran it enough to need a drum I can't imagine that .
May 15, 2008 | Xerox FaxCentre F116 Plain Paper Laser
Fax
i need simple instructions to operate the receiving and sending of fax information on this lexmark 4270 fax machine .
Jan 16, 2008 | Lexmark X4270 All-In-One InkJet Printer
Need help on my lexmark x 4270
Fax does not require installation on the PC. Driver for Vista is here: http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:438:0:0
Aug 29, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X4270 All-In-One InkJet Printer Logo
171 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
