Question about GE DCSR483EA Electric Dryer
No heat on my GE prodigy dryer dpxr483
How can I get to the resistor or the thermostat. finside the dromb or to the back
  • GE Master
  • 19,396 Answers
Here you get exploded view, so that you can locate the thermostat. There are two thermostats at the back of the drum, they are numbered 505 and 507 in diagram.
Here is the diagram
To access the thermostats, remove the back panel (see diagram), and undo the belt routing.
Posted on Sep 29, 2008
Dryer does not get Hot
sounds like heater element or heat sensor
Jan 31, 2012 | GE Profile Prodigy DPSR513GA Dryer
Why is my dryer not produceingheat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE Prodigy dryer makes an electrical buzzing sound when I try to turn it on and it won't turn on.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
We have a GE Prodigy clothes dryer that makes a very loud sqeacking noise when it runs
sounds like a rear drum bearing thats gone bad very common with these units, the front bearing and slides should also be checked for wear at the same time,to replace bearing in back drum has to be removed completely. if your handy with tool and have and afternoon to kill its not that bad ,just rember to UNPLUG UNIT BEFORE ANY WORK
Aug 06, 2010 | GE Profile Prodigy DPSR513GA Dryer
My GE Profile Dryer is still operating but produces loud intermitent noise as the drum rotates. What can I do to eliminate the noise?
It sounds like you may have a bad bearing in the back of the drum. That model rotates on a sort of ball and socket type mechanism. You may be able to lubricate it if the noise is just squealing/squeaking. If it is more than that, you'll probably need to replace the bearing mechanism. If you lube it, use a heavy weight lube that is rated for high heat (I've used brake caliper grease.)
Jan 03, 2010 | GE Profile Prodigy DPSR513GA Dryer
Not getting heat from dryer
check the high limit switch and glow rod
Sep 15, 2009 | GE Dryers
No heat
make sure the drier vent is cleaned out of all the lint including under your filter screen in the drier all through the drier hose and out the vent to the outdoors
Apr 23, 2009 | GE Profile Prodigy DPSR513GA Dryer
GE profile prodigy - dyer
hi. the vent inside the dryer needs to be cleaned.you must live in a warm climate. clean all air vents inside the dryer, and out. thanks the appliance doc
Oct 04, 2008 | GE Profile Prodigy WPSE4200A
No heat
need to ck the heating element, to see if any breaks in wire coil.
Sep 27, 2008 | GE DBSR453EBWW Electric Dryer
GE Prodigy Electric Dryer not getting hot
The exhaust hose in the back will not affect whether the dryer will heat. The hose just removes the used hot air to a place outside your house. I assume dryer drum spins, but you get no heat. If the dryer has gotten a few years of use, I suspect that the heating element has gone bad. Have you noticed that it has taken longer and longer to dry clothes than it used to? If so, most probably the element is bad. The element is not unlike a heating element in an electric stove, and is housed in a duct inside the dryer.
Mar 10, 2008 | GE Profile Harmony DPGT750EC Electric...
GE DCSR483EA Electric Dryer Logo
343 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
