Question about Canon PIXMA iP3000 InkJet Photo Printer
Ip3000 won't take the paper
Hi, I'm trying to print but the paper won't go through...when I click to print it tries
to start...takes the paper for a moment...and stops...seems it won't grap it good....
Puch the button under the continiu-button. or fill the casette with paper.
Posted on Oct 27, 2008
Wsouthwell@sbcglobal.netMy ip3000 does not print at all..the paer runs thru fine but does not print, the tanks are all good, there are no error messages..where do I start looking? Thanks
HI there,
What operating system are you using?
Please try reinstalling the printer driver and check if that will do the trick.
Hope this helps!
Aug 24, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
How do I change the paper source from the tray to the auto feed?
Hi there
You goto go to the tabes when you go to print, try the setup in it is in there.
No problem all the way from Wales UK for you.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Canon-iP3000-iP4000-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Apr 28, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Error code while trying to print
Slap the printer with your right hand from the right side of the printer.This process always solves the problem. I did, it worked
Apr 01, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
I cant get the machine to grab the paper and it says its out of paper, yet its not out of paper.
Hi, the Ip3000 has 3 different feeding trays...
make sure that the printer is trying to "grab" the paper in the tray that you have chosen to use in the printer properties box...
when you give the print command can you see the rubber roller moving to grab the paper in the top feeder tray???
if the roller that feeds the printer is not moving you may have accidentally changed the settings to grab paper from the bottom tray...the one right under the door that opens to let printed pages out of the printer...
the 3rd feeder tray is the DVD/CD printing tray...
I suggest that you look at the printer Properties for remedial action...
hope this helps you with your problem...
cheers
haitchhcee
p.s.
suggest you place paper in the bottom tray before making adjustments to see if it is trying to grab the paper from there...
Dec 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
My canon inkjet pixma ip3000 says it has no paper when it has. It has worked before but now it just says paper out when i try to print.
this i think is simple. you put the paper on wrong. it sometimes happens to me on me printer. look at your operating manuel to see how to properly put on the paper
Oct 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer does not print documents. Model IP3000 pixma. Approx 3 years old, used in my classroom. Printer has been working well until this morning. This is a sudden failure. Performed all maintainence with...
I had this very same ongoing problem with my iP3000 and recently with my iX4000 but I refused to believe it was the printheads as the iP3000 would print cd/dvd discs without a problem. Colour on paper was always there even though I used Calidad tanks.
My solution, or more aptly, my workaround was to change the paper setting from Plain paper to Glossy paper but still using plain paper and low and behold, after nine months of test pages with only the Windows logo it stated printing black text again albeit slowly now. Same deal for the iX4000, it started printing black text on plain paper as well after 4 weeks when the problem first occurred
I also did all the maintenance rigmarole over and over etc...with no results. My printers are hooked up to two PC's, Vista and XP so maybe I eventually scrambled the printers barins or something, anyway I'm printing again.
Worth a try and nothing to lose
Sep 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
IP3000 WILL NOT PRINT BLACK
Try Start --> Control Panel --> Printer and Faxes
Right click on the printer --> slect Properties
Look for maintenance and try "clean" or "Deep Cleaning"
If you cannot find "Maintenance" look for "Tools"
Jan 13, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip3000 paper feed jam
try cleaning the rollers with alcohol, the tires are probably dirty and one side is not gripping the paper.
Jun 19, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Dimantle my canon pixma ip3000
I had this problem yesterday with my iP3000, but it turned out to be my own fault. I had randomly pushed the control panel buttons, as I tend to do that with printers, while I was trying to quickly cancel a print job.
The symptoms:
roller wouldn't advance, a lot of noise like it was trying to advance, then two yellow light error flashes. I knew it wasn't out of paper.
By randomly pushing buttons, I clicked the Paper Feed Switch which toggled from top sheet feeder to cassette.
I downloaded the e-user's guide from Canon and learned what those control buttons are. I simply clicked the Paper Feed Switch and it toggled back to top sheet feeder. That fixed it for me.
Dec 07, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Paper jam on 1 side
at start paper jumps in gear pulls to one side
Sep 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
61 people viewed this question
old marine
old marine
