Connecting a pc to a television
What lead do i need to connect my computer to a television,so that i can use the television as a monitor.
  • Anonymous Dec 25, 2008
    Tv screen fuzzy when connected
  • jangwal2 Jan 04, 2009
    i have sony bravia lcd and my pc hp i connect pc with tv with vga back ground screen saw but not icon of computer like internet ect;;;;;;;;
If you can see the background screen it means that you have to drag the programmes off you computer monitor off the screen and it will appear on the tv.
Posted on Jan 05, 2009
My monitor turns on but does not display any picture.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive including electrical extensions IDE SATA the leads from your ((motherboard to your hard drive)) make sure they have secure dust free connections and are not faulty or just replace them they might be faulty if its a 40 pin flat ribbon type it will be the first to fail make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure dust free connections and are not faulty even something as small as an electrical fan and its lead can cause you problems computers need all power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error make sure your graphics card is securely seated with no dust built up or in the socket if you remove your graphics check the socket to make sure its dust free restart your computer then reinstall it this should activate found new hardware wizard or you might try You will need to connect to another monitor or your television to your computer with the vga lead monitor connection. Click start control panel display change display settings adjust resolution this may vary depending on your operating system You should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes. If you can get an extended desktop your monitor is faulty if you cant get an exended desktop Hope this helps.
Jan 14, 2013 | HP Pavilion a1120n (PX759AA) PC Desktop
If my hp a410n pc has power, why wont the monitor come on
Jan 14, 2013 | HP Pavilion a410n (DQ174A#ABA) PC Desktop
No power to monitor
You didn't provide the Model of the eMachine?
Jan 05, 2013 | E-Machines eMachines Desktop PC
Using a tv as a monitor
Hope this helps
Nov 22, 2012 | eMachines ET1161-03 PC Desktop
In wespro netbook the boot screen did not appear, it shows blank and blank, can you help me ?
Test all leads that attach to your hard drive including electrical extensions SATA
make sure all leads that are attached to your drives dvd\cd have secure dust free connections and are not faulty even the electrical extensions
computers need all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
or you might try
you will need to connect to another monitor or your television to your computer with the vga lead monitor connection
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system
or click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
if you can get an extended desktop your monitor is faulty
hope it helps
Jun 20, 2012 | Computers & Internet
Black screen on pc laptop
you should see a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause this problem or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
hope this helps you
Mar 20, 2012 | LG Computers & Internet
I have no screen. I can use it with an external monitor. But the monitor does not show up at all
you might need to replace this monitor
or you might check the lead/s that are attached to the monitor they might be faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 25, 2011 | Computers & Internet
Monitor doesn't show anything everytime I boot my PC. Power produces a clicking sound. I checked with the wires, sometimes the monitor does come back to work and sometimes it does not.
don
Feb 23, 2011 | HP Vs17 17" LCD Flat Panel Monitor
What leads do i need to connect my pc to my sony tv
you need to change the input on your tv to pc or ect. you need a monitor wire if your tv has a port for it, most flat panel computer monitors have a removable connection just connect it to your tv and your computer should work. you wll have to change the in
Aug 22, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Built in speakers
Ya, you have to connect an Audio Lead from the Monitor to the Computer. The audio lead would had been shipped along with your Monitor.
You have to connect the "One End of your Audio Lead in the Audio Out socket of your PC and the Other End in your Monitor's Audio In socket". Thats it.
Apr 21, 2009 | Maxdata Belinea 10 17 25 17" LCD Monitor
Televison & Video Logo
311 people viewed this question
Top Televison & Video Experts
Electro Med Services...
