Question about GE Spectra JBP78 Electric Kitchen Range
Stuck door latch after cleaning
I have an electric Spectra. My wife went to self-clean it and stopped the process when flames started (left over cookie dough). Now the latch won't fully disengage. I tried cutting and restoring the power, and ran another Cleaning cycle which went through without incident. Still can't get the latch to fully disengage. Door will open a crack and the light will come on but that's it. Any thoughts? Thanks
Door latch stuck but the door is open and i can't close the door back
Posted on Feb 01, 2009
I started the self-cleaning process on my GE electric oven last night. The process is complete but the oven door will not unlock. It sounds like it keeps running and running.
You can start the self cleaning cycle again and then stop it after 15 minutes, then let the oven cool for sometime and check if the door opens again, if it wont work then press the CANCEL button for 20 seconds. If the issue returns then you have to take a screw driver and open the latch. After this the latch mechanism should be replaced as it is bad. Hope this helps...please post back for further assistance.
Jan 17, 2011 | GE JTP15 Electric Single Oven
I went to use the auto clean on my oven....turned the knob to "auto clean" then turned the oven door latch to the right to lock it. i found out the auto clean took 4 hours (don't have time to do it today)...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Sep 08, 2010 | Hotpoint RB787 Electric Kitchen Range
I am in the process of cleaning my Whirlpool self cleaning oven and it seems like there should be about 2 hours left on the timer and when I came out to the kitchen the timer was off and the door is still...
most likely the safety latch got stuck from the super heat of the oven while cleaning. try tapping the latch with a screwdriver and hammer, spray a bit of wd-40 on it wont hurt. i believe the self cleaning on ovens is crazy, as the heat damages things, including the finish of the unit.
Jun 22, 2009 | Whirlpool RBS275PD Electric Single Oven
I started the GE self cleaning feature on my GE
It will stop when it is done cleaning, usually about 3 hours.
Jun 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I have no manual and do not know how to use self-cleaning function. I have a Hotpoint electric self-cleaning oven. I can't find a manual and the only model number I can find is on the door PLT083-2. The...
The latch wouldn't go all of the way over. I pushed it over until the blinking light went off. The latch doesn't seem to catch but I did get it to work. Thank you for your help though.
Apr 09, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Will not self clean
soundsas if theres an issue witht the latch assy not recoginzing teh door is closed, and for safety reasons with out door closing will not engage cleaning cycle
Feb 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I don't remember how to use the self cleaning feature
Remove everything from the inside of the oven, lock the door if your model has a latch handle that you move from left to right to lock the door, then set the oven selector switch to clean.
Dec 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
JTP56 Self Cleaning issue
It sounds like you need to replace the door latch assembly. One of the switches on it is not working properly so the control is not getting the correct signal for the door latch position. It could be an oven control problem, but most likely it is the latch.
Post back with the complete model number from the oven if you need more help and I will answer as soon as I can.
Thanks, Mike
May 06, 2008 | GE Profile JTP56 Electric Double Oven
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
Feb 10, 2008 | Kitchen Ranges
GE Spectra JBP78 Electric Kitchen Range Logo
220 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
