Question about HP LaserJet 4 plus Printer
HP LaserJet 4 plus
Tray full but paper concertinas through rollers
    Problem Solver:
  • 10 Answers
I am assuming that you have an jammed paper in the back door or an accordion jam in which the paper is all folded up or crinkled. if that is the case the printer needs the output assm replaced (hp part number rg5-0886). which is pretty simple take out screws for top cover remove top cover at rear of machine once cover is off there are two taabs holding assm in place depress tabs rotate assm slighlty and lift out of place reverse process to reinstall takes less than 5 minutes to complete.
Posted on Oct 22, 2008
How do you manually feed legal paper into a HP laserjet 4 plus (model 2037A)? It only has a letter paper tray. I inherited it without a service manual
The LaserJet 4 plus I have worked with had a paper tray that was adjustable for letter or legal. If yours is not, there should be a door on the front of the printer that will pull down at the top, and is hinged on the bottom. Open the door, you will be able to extend the "paper tray" and put a small amount of legal sheets on it. Go to the menu and tell it to print to this paper tray, I believe it is paper tray one.
Aug 02, 2013 | HP LaserJet 4 plus Printer
HP LaserJet 4 Plus printer, as the paper is starting to feed into the printer from the MP tray the paper on the left side pulls in crocked and therefore causes a paper jam. Pick up roller and seperation...
There is something blocking the paper path.(Like a paper clip or something). Remove the toner cartridge first, then use a file folder or thin cardboard to push the object out of the way. Put the toner back in and try printing again. Good luck !
Apr 03, 2013 | HP LaserJet 4 plus Printer
HP Laserjet 4plus chewing us paper
This is most likely cased by a dirty paper feed path so it will need cleaning and blowing out. Make sure that all the internal paper guides and separators are free of obstruction. Make sure that the fuser area is clean that the internal paper guides are ll in place and operate freely. Also clean it with a vacuum with a soft haired brush tool to avoid any damage. Also fan the paper before using it and do not overload the print paper tray. Also check that the pick up rollers are not work or contaminated with dirt / debris etc. Also make sure that the print tray is not overloaded and make sure that the paper is not to tightly held by the tray side guide.
Sep 30, 2009 | HP LaserJet 4 plus Printer
HP Laserjet 4 plus printer
use the m/p tray.configure printer to print any size.
Jun 25, 2009 | HP LaserJet 4 plus Printer
Lasejet 4 plus- try to print. lower paper cassete full. printer screen says pc load letter and have to manualy load paper. print icon on computer says out of paper
There is a paper empty flag sensor, looks like a plastic paddle, in the tray area. Pull out the paper tray and flick it; make sure that it is not jammed.
Also on the right hand side there is a paper pick- up roller, clean it with a cloth with some alcohol. See page 4-13 for the location of paper feed pick-up roller. page 5-27 shows the paper empty sensor flag
Here is the service manual: Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 06, 2009 | HP LaserJet 4 plus Printer
False ricoh 1224c paper jam warning
check tthe clips retaining teh feed rollers havent sliped off if it isnt picking up from tray take the tray at top out and then watch from above to see if the rollers are turning to feed paper.. if the lifts out check the side door guide isnt out of plavce check the end paper guides as well//check when you take the tray out look to see there is any paper stuck at the back where the tray sensors ares can cause a lift motor error aswell
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Error 13-jam paper HP Laser 4+
HP LaserJet 4, 4m, 4 Plus and 4m Plus Series Printers - False Error Message 13 PAPER JAM ISSUE: After clearing all jammed paper from the HP LaserJet 4, 4m, 4 Plus, or 4m Plus series printer, the display still reads 13 Paper Jam . Even after cycling the power off and then back on, the error remains. SOLUTION: Open the rear door of the printer. There is a paper sensor near the upper right hand corner of the fusing assembly (just below the right edge of the long yellow warning sticker on the fuser) that can cause paper jam error messages even when there is no jammed paper in the printer. Toggle the thin black plastic lever up and down to make sure it is not stuck or sticky. The lever should be in the down position before closing the back of the printer. If the lever is stuck or missing, the printer will generate a false paper jam message. Hope it will help you !
Apr 02, 2008 | HP LaserJet 4 plus Printer
HP color LaserJet 2550n
Look at your printer properties and check that you are using the correct tray settings.
Jun 12, 2006 | HP Color LaserJet 2550n printer + HP Color...
HP LaserJet 4 plus Printer Logo
215 people viewed this question
Ben Johnson
