Question about JVC Everio GZ-HD7 Camcorder
Communicating error when using battery
I got a "Communicating Error" when using battery on my cam.
I works fine if i'm using the power from the supplied power adaptor connected to domestic power.
  • Cee Jai Bernard
    Cee Jai Bernard May 11, 2010
    What are you trying to do.. just use the camcorder in general? Also, the battery you're using, is it an authentic JVC data battery or is the battery made by a different company?
Yes am just using my cam and suddenly that error occurs. yes am using original JVC data battery. anyways i already brought it to a jvc service center and it's already fix. they're not so clear what really happens but they got it running again after 5 weeks in their hand.
Posted on Oct 29, 2008
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
Error code 000480, will not allow me to delete internal memory, says redo. is not recognized when it is connected to my laptop. brand new batteries & sandisk sd card. help!
Error code 000480="cam mod test/comm error...it is not communicating with SD card...may be bad main board ...get my parts from other defective cameras...Moultrie will tell you to buy new camera.
Jun 22, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My jvc gz-mg330 dont work and on the srean its said communicating error
I presume the error is in between cam CPU and the Data Battery. Check your battery contact and camera's battery terminals and clean especially the pin marked "c". This contact is the link between BATTERY and CAMERA CPU so that your cam knows how much power left in your battery. Sometimes a DC JACK failure or defective battery shows the same warning. Good Luck!
Mar 16, 2010 | JVC Everio GZ-MG330 Camcorder
Moultrie I40 getting error code 480 and wont go into auto mode
ERROR CODE 000480 ?
If this is correct,it relates to: Camera Mod test failed;(4); and under Memory Test, 8= Comms Error.New batteries(good ones) may fix it...
It' not communicating with memory card..ck it's inserted good..press down until it stays down(press again and it will pop up.
Follow instructions on deleting internal memory before installing SDcard.
Also, make sure cam supports kind of card you're using..at 4gb and larger, they become confusing;i.e., 4/8/16mb...older cams won't support some of these. Also there are HC(high capacity); HD(high definition)don't work in these cams..
I posted this for a fix a few days ago, and it turned out to be brand new bad batteries.
Dec 23, 2009 | Moultrie GameSpy 4.0 Digital Camera Deluxe
One of the 2 battery does not work on camcorder.
some of those batteries come with a lid on the face side of the battery where u insert a power cord in order for the camcorder to get power from the battery. (strange........ I know). the battery mounts on the camcorder but acts as as an external source of power. a cord needs to be plugged into the battery and then int the ac adapter jack in order to send power.... that is if it is anything like my camcorder.
May 30, 2009 | JVC Everio GZ-MG130 Camcorder
Error when communicating with the phone
hi, download the latest software for the phone from www.nokia.com and this will sort the problem out, it is a common issue
Jan 02, 2009 | Nokia N73 Cellular Phone
Sony handycam DCR-DVD205: use new ac adapter or reinsert
Remove the battery insert your AC adaptor turn on your DVD CAM if it work fine reinstall the battery set CAM to off position the amber light should be on to indicate battery is charging
You got that msg depend what function you use if the CAM calculated the battery not enough to run or finish this task it display that msg for you to use AC adaptor to ensure no power corrupted such in formating the disc
Some time system control is faulty even you use AC adaptor it still display this msg I hope that is not in your case
Let me kown how you go with this problem
Nov 30, 2008 | Sony Handycam DCR-DVD205 DVD Camcorder
JVC EVERIO HYBRID GZ-MG330 Battery error?
I bought a replacement data battery BN-VF-808U from Digicowfish through Amazon.com. (?made by PomerPower).
It fits nciely to my JVC Everio GZ-MG330 which uses a BN-VF808U data battery. However, JVC gives a screen message:Communicating Error.
Now I have solved my Communication Error by using a jumper cable provided with the replacement battery BN-VF808U to connect the attached replacement battery to the camcorder. There is a DC input socket on the camcorder. There is also a DC input socket on the replacement battery for direct connection.
JZC
Aug 06, 2008 | Video Cameras
Scanner component stopped communicating
well, reinstall the software and see if it will work.
Aug 13, 2007 | HP PSC 1350 All-In-One Thermal Printer
JVC Everio GZ-HD7 Camcorder Logo
539 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
