Question about Xante Office Equipment & Supplies
We just replaced the waste duct assembly and the gear coupling and registration unit on our xante ilumina and now we have a contants error "close side door" are there sensors we are missing somewhere that possibly didn't get reconnected and where are they located?
rooboy
  • 24 Answers
SOURCE: Xante Ilumina 512 error code
this error can be caused by a new or existing PC on your network. EXAMPLE: the network settings on new DELL pc's are default set to control the network and repair any conflicts..it seems dells dont like Ilumina's, and they get this error code.
Disable the network control function in the DELL settings.
And this error will not re appear until another dell is installed.
Posted on Jul 23, 2008
rooboy
  • 24 Answers
SOURCE: full bleed printing
feed the stock thru the Multi prupose tray. Set a custom size in the PDD to 5 mm larger diamension for W and H. this fools the machine to thing larger stock is being printed. feed your original stock. do not scale to fit....and presto, you can print to full bleed...
Posted on Sep 21, 2008
You need to install duplex in your windows driver printer dialogue
Posted on Oct 12, 2008
  • 202 Answers
SOURCE: how to install xante ilumina drum units?
When you unpack the drum it has like a white nylon and three orange plastics. Remove the three plastics(tapes are holding the plastics) and at the end remove the white plastic it has an arrow. Do not touch the drum. Make sure not to much light hits the drum. You have four drums remember to sit correctly the drum and to its correct position.
Posted on Mar 16, 2010
  • 202 Answers
SOURCE: Good day
Your settings are incorrect, adjust media type and media weight. This settings adjust the temperature of the fuser. If fuser to cold you will have ghosting and fuser to hot image will stick to fuser.
Posted on Apr 01, 2010
How i can fix this problem 929:fatal error .
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
May 16, 2014 | Xante Ilumina Digital Color Press Printer
Yellow registration problems on xante 502
clean all the registration sensors on the imaging drums and at the fuser end (there are 3 under a shifting piece of white plastic on the left side after transfer belt is removed.
May 15, 2014 | Xante Ilumina Digital Color Press Printer
Xante fatal error 929
Feb 11, 2014 | Xante Ilumina Digital Color Press Printer
Waste toner near full
there is a white gear whre you install the waste toner box, that is connected to the box. see if it's broken - yoy will see the spring that is inside the gear
Sep 20, 2013 | Xante Ilumina Digital Color Press Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
230:fatal error with Xante Ilumina
RFID Reader Not Installed
Check Connections. Replace the RFID Relay Board Replace the Engine Board.
Jan 09, 2013 | Xante Ilumina Digital Color Press Printer
Xante ilumina I have an error code 134:fatal error , please help!!!!
LED Head Error
131 = Y Head 132 = M Head 133 = C Head 134 = K Head
Sep 21, 2012 | Xante Ilumina Digital Color Press Printer
Please what can I do to work the machine that says fatal error 133; for xante ilumina
If you are in a Windows OS it means that:
133 JOIN or SUBST command can not be used for a drive that already contains readers joints.
So uninstall your printer and install it again using the best driver.
Nov 10, 2010 | Xante Ilumina Digital Color Press Printer
How to install xante ilumina drum units?
Jul 02, 2009 | Xante Ilumina Digital Color Press Printer
Jun 04, 2008 | Xante Ilumina Digital Color Press Printer
46 people viewed this question
Top Xante Office Equipment & Supplies Experts
Igor Studennikoff
Igor Studennikoff
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
