IMO Never Use a cleaning disc for Gaming consoles. Which Xbox 360 do you have? Is it the Older Model or newer one? You can Try Blowing into Your Xbox disc drive. Is your xbox up to date,you can unplug your xbox 360 and from the wall and the Xbox. Wait 25 Mins and Try again.
You need to completely uninstall the software and try to reinstall. If the clean install does not work than most likely your system doesn't meet the necessary requirements or the software is not compatible with your system.
Well it sounds like the console it's self needs to be cleaned out then 4.5 mm bit screw driver to open her up lukue games sell those 4.5 mm game bit tool compressed air to clean it out and it should work
See if your ps2 controller hub or port is damaged. If any pin is twisted try to get it straight and if you can't fix it, take the console to a service center.
There are many things that can cause that problem. Try removing it then rensert it again while your NDS is turned off. If that doesn't work, try other game cards if they will work. If other game cards work, then the problem is with the game card that can not be read. If you are using flash kart, then you might need to reinstall the software for it by downloading from their website. Goodluck!
The Playstation 3 is a wonderful video
game console, however, with heavy usage, the laser does eventually burn out.
The first signs of the laser starting to burn out is that your game will start
freezing during game play. Eventually the game will stop reading altogether (even
though movies sometimes still work). Eventually movies will stop working and
the whole laser will eventually die.
The following website sells PS3 lasers and also performs repairs:
The superscope uses an infared sensor as well as light detection to work
Chances are that some form of interference is going on so try moving your sensor
You could als ojust have a bad super scope and It's dying out
Thank you for your time Good luck and I hope this helps
I don't know a lot about this console (the Retron 3), but the game sounds like it works fine, try using a different third-party console, I recommend the Retro Entertainment System, it's only around $20 - $25 on eBay, try a different NES game, if it doesn't work, than it's probably the controllers, get replacements, or the batteries are dead.
