We have a bosch classixx free standing dishwasher and the base is filled with water, we ve removed the filter but there doesn t seem to be anything there causing the blockage.any ideas?
Hello Becky,
The most likely causes are a failed drain pump motor (or capacitor) or a jammed/broken pump impeller. There is a very simply simple test on classixx models which which help you to determine the cause, or where to look next.
1. Turn the wash cycle selector to any wash cycle so the "ON" light is illuminated, but do not press the START/STOP button.
2. Open the door and pull the lower basket out.
3. Locate the 'float', lift it up fully and keep it held up.
(The float is a dome/mushroom shaped protrusion in the base of the washer just to the left of the drain and partially hidden by the spray arm)
When you lift the float, the drain pump should run instantly and the water should drain from the washer. If you can hear a low hum from the pump motor in the base of the washer, but the water doesn't drain, then it's likely that the pump impeller is jammed or it may have broken away from the spindle. If this is the case, try repeatedly lifting and dropping the float fairly rapidly. Repeated stop/start signals to the pump motor can sometimes free a stuck impeller.
If you cannot hear any noise from the base of the washer when you lift the float, then the drain pump motor or the motor capacitor may have failed. A failed capacitor is often accompanied by a buzzing noise. Further testing will be required to determine the exact cause of the fault.
Please try the simple test above and then post back with the results for further assistance.
Hope this helps.
Regards,
BElectric
