Question about Kodak EASYSHARE 5100 All-In-One Printer
Will not print in color
Printer will only print in a light blue . BOTH  cartriges changed.
  • SHELLMAXUS Oct 14, 2008
    MY PRINTER BROKE AFTER THREE MONTHS , AFTER CHANGING CARTRIGES ALL THE TIME THINKING THEY WERE EMPTY, MY PRINTER JUST WONT PRINT BLACK OR COLOR, WHAT DO I DO WALMART STORE WILL NOT RETURN ITEM SINCE IT IS THREE MONTHS OLD. CAN I RETURN IT TO KODAK TO FIX?
Printer will not work properly
Posted on Oct 07, 2008
I had a similar problem. I called Kodak Tech Support about 10 mintues ago and the rep determined I needed a new printhead. They are sending it with new black/color cartridges and will be here within 2 business days.
Posted on Oct 06, 2008
  • 3 Answers
Go to Kodak website,look for support, and repair. Online testing will probably determine that a new printhead is needed and they will probably send you a new one. My printer is only 9 months old and it has same problem.
Posted on Oct 05, 2008
hemantraj
  • 638 Answers
SOURCE: H.P.Deskjet 5150 printer
TRY CLEANING THE SURFACE WITH MOIST CLOTH THAT CONNECTS WITH UR COLUR CARTRIDGE CIRCUIT.WISH U SUCCESS
Posted on Jun 03, 2008
  • 352 Answers
SOURCE: COLOR DOES NOT PRINT, NEW CARTRIGE INSTALLED
Try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 12, 2008
  • 8 Answers
SOURCE: Printer cartridge alignment
You can also bypass the alignment. When the message for alignment displays on the display => Press Setup and Options (or Copy Options ) simaltanious.The last known alignment is used when the alignment is bypassed.
Posted on Nov 02, 2008
  • 628 Answers
SOURCE: Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Posted on Mar 15, 2009
  • 55 Answers
SOURCE: Printer dont print without one of color ink
u should use all cartrige for printing with your printer
Posted on Apr 24, 2009
It prints blue instead of green when i print. anything that should be green turns out totally blue. any help? i've reset and calibrated twice.
have you tried replacing the color cartrige if so then the printer may be broken and uses the wrong colors its uncommon but does happen
Dec 19, 2009 | HP LaserJet 3600n Printer
My printer does not print blue color. I changed ink but it still does not work. Instead of blue every time I get pink. what can i do? Everything was normal?
Did you reinstall the drivers? and IM not sure on the printer does it have seperate colors cartarges I know some of their printers do
Dec 12, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Printer Cartrige Problem [Tri-Color]
if the printer queue is empty and you have turned both comp and printer to off it should reset.
Frpm your explanation it sounds like your color cartridge has a problem Tricolor red,blue, yellow maybe one is empty the black is a separate cartridge
Jun 21, 2009 | HP J4680 Office Jet All-In-One Printer
Apr 24, 2009 | Office Equipment & Supplies
Problems with color prining
hi!!!!
perform maintenance and
try to clean up nozzles may be the ink
clog
or removed the cartriged and clean with alcohol
use cotton buds then placed it back properly
Oct 31, 2008 | Canon BJC 2100 InkJet Printer
450c color problem
The 430 ID is B/W, you need to load the 450C driver to get color, renaming the driver isn't enough.
Oct 13, 2008 | HP DesignJet 450c InkJet Printer
Mfc 210
if the MFC is a brother..your print head could be dead.
Jun 21, 2008 | Brother MFC 210C All-In-One InkJet Printer
Print Out
yes replace the cartridge it appears the cartrige is defective
Dec 06, 2007 | Dell 924 All-in-One InkJet Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
63 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
