Question about Plumbing
What type of fluid,
What type of fluid to use for toyota mrs power steeering,
  • blueextc3221
    blueextc3221 May 11, 2010
    MRS?
    Do you mean MR2?
    Scholar:
  • 89 Answers
Its a safe bet to refer to your owners manual for that kind of info, but if its ran dry dextron II or dextron III
Posted on Jan 11, 2009
Power Steering Fluid
Gran, Toyota OEM power steering fluid is ATF (automatic transmission fluid). Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.urbanlandcruisers.com/products/fluids.html
1 Litre Genuine Toyota ATF Automatic Transmission Power Steering Fluid
power steering fluid ok instead of ATF
http://www.toyotanation.com/forum/132-9th-gen-corolla-1st-gen-matrix-2003-2008/411459-diy-2003-2008-corolla-matrix-pontiac-vibe-power-steering-fluid-exchange-w-pics.html
Aug 20, 2016 | Toyota LandCruiser Cars & Trucks
What power steering fluid do I put in my 1994 Toyota camry?
How Do I Check/Add Power Steering Fluid to My ... - YouTube
? 2:55
www.youtube.com/watch?v=mtQfJ31MLxk
Oct 21, 2010 - Uploaded by 1A Auto Parts Auto Repair: How Do I Check/Add Power Steering Fluid to MyCar or Truck? .... What type of power steering fluid could I use for my 2003 Ford Explorer? .... Toyota 4 Runner Steering Problem Returns - EricTheCarGuy ..
Oct 15, 2015 | Toyota Cars & Trucks
Power sterring makes wering noise and gose hard at low revs
Power steering makes wering noise and goes hard due to more than like been very lowe on pwer steering fluid .
1.power steering pumps normal leak fluid in the commodores and need replacing.
2.steerings always leak.
3.Also check the hose that come from the p/steer resvoir and even p/steeer cooler hoses and the metal pipe that mounted at the front of the radiator these are all very common faults
May 24, 2014 | 1998 Holden VT Commodore
What type of power steering fluid do I use for a Toyota Yaris 2008?
Toyota recommends total lubricants.you can total FLUIDE DA for your steering fluids! please note dont put excess fluid, i mean not more than denoted level.
Jan 14, 2011 | 2008 Toyota Yaris
What type of power steering fluid should i use for my 1987 toyota pickup?
Id use some Lucas power steering fluid with stop leak and conditioner, works pretty well. If you cant get that than any power steering fluid will be fine
Apr 04, 2010 | 1987 Toyota Pickup
When on the freeway and my power steering "turned off", which has
With the power steering quitting immediately, it indicates a broken belt or serious lack of power steeering fluid. If it's fluid, you have a leak allowing it to escape.
The "tapping noise" sounds like it might be the belt flapping around with engine running.
Feb 16, 2010 | 1999 Honda Prelude
Power steeering started makin a noise & noise gets louder when turning wheel. Fluid is aerated & if top of resivior removed while engine running fluid flys out. Have recently had new belts fitted...
belts were put on too tight or have gotten too loose after they were replaced. the nuts that hold the parts in place may not have been tight enough causing the parts to move , which loosens the belt. maybe the belts were stretched too tight when replaced,....... either will cause squealing...good luck
Feb 02, 2010 | 1994 Toyota Camry
Type of power steering fluid for 2001 toyota camry
Power steering fluid - Dexron 2 or 3 automatic transmission fluid. Yes transmission fluid. And while you are at it check the fluid level in the transmission.
Since you got the hood up, check the brake fluid, wiper fluid, radiator fluid, battery fluid, oil level.
Apr 26, 2009 | 2001 Toyota Camry
Where do you put the power steering fluid in a chevy hhr 2006 model
the power steering fluid resevoir is located on the passenger side of the engine compartment near the fire wall. mostimes in order to fill it you have to remove the altenator to remove the fill cap to add the fluid.
Apr 17, 2009 | 2006 Chevrolet HHR
Plumbing Logo
60 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
