Question about Lexmark X1195 All-In-One Printer
Software I am running Windows XP I would like to download the software so that my printer will scan, copy etc
  • Lexmark Master
  • 19,396 Answers
If you do not have the disk you download software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
Afterdownloading,findthefile,doubleclick on the file, if you get introubles ,thenfollowinstructionsbelowto reset and reinstall:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website and run the file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Posted on Sep 29, 2008
I can't found any scanner driver.....i can print but scann....it's impossible SCX-4300
What OS are you running? I don't see any full-feature software but the Samsung site lists a print driver, a scan driver, a universal print driver and a universal scan driver for Windows 2000 through Win7 x64. Similar drivers are also available for the Mac OSX. I'm not certain of the features in the "unified driver" for Linux. The full-feature software is available for Windows.
To find these drivers, go to http://www.samsung.com/ph/consumer/monitor-peripherals-printer/printer-multifunction/mono-multifunction/SCX-4300/XSS/index.idx?pagetype=prd_detail&tab=support . Click on the Downloads tab and then select Driver. The windows files are all .exe files.
For the SmartThru software go to the above link and select Software instead of Driver. With this software, you will be able to launch a scan from the printer if the monitoring program is running. You should be able to start a scan from the computer with any OS and the Samsung drivers.
Windows XP, Vista and 7 can all acquire scans with Windows software. You can use Paint in all three (File > Import from Camera or Scanner > New Scan). Vista and Win7 add Windows Fax and Scan (New Scan). Vista came with Photogallery and it acquires scans like Paint. (You can download it for XP or Win7.) The Mac also can acquire scans with included software.
One issue that can cause a scanner problem is a bad cable. Scanning requires bidirectional communication with the printer and thus may fail when the printer works. Replace the data cable and make sure to use a direct connection (no USB hub or print server) if you can launch the scan but then it stops.
I hope this helps.
May 15, 2011 | Samsung SCX-4300 Monochrome Laser...
I have got a Xerox Docucolor 12 printer, a Fiery X12, and a laptop running on Vista. I dont have any cables except the power cables and was looking for a list of everything I'd need to get it running...
There are 2 cables that go between the fiery and the printer, not sure where you can get these.
You will need to be running windows xp
connect to the fiery with an ethernet line
download the drivers, command workstation, and fiery remote scan from the xerox website
hopefully the fiery still has its software loaded otherwise post a request for a copy here.
Nov 11, 2010 | Xerox DocuColor 12 Printer
My Lexmark 4550 will not sacn wirelessly, how do I
Hello. Try to run the installation cd in your computer again. If you haven't tried to uninstall the software from your computer, the cd should give you three options: Install a Printer, Repair/Update and Install Additional Softwares. Choose Repair/Update and just let it run and finish the installation. Also, make sure to allow all Lexmark and printer communications in your firewall. Try to scan wirelessly again. If problem needs further troubleshooting, I advise you to call Lexmark.
Mar 31, 2010 | Lexmark X4550 InkJet Printer
I have an epson stylus photo rx500, but have lost the installation disc and have no smart panel function so cannot scan or copy and espon are useless and say it was a bundle and newsoft supplied the...
You do not actually need Smart panel to use the scanner. Epson scan will allow you to scan and save to the PC etc. To install the printer and scanner download and install Epson Scan and Driver from the following page. http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=SF8cgjsfr7MDXMcEkJfQFa89pC7QCDCv&tc=6#7
Jan 17, 2010 | Epson Stylus Photo RX500 Printer
New printer problem
Check that you did not install a 64-bit driver on a 32-bit system, Vista driver on Windows 7, etc. unless that is what your system specifically requires. Do not install the full package either, download the link on the website that says "driver only". A lot of the software printers install are kinda crappy because they assume you have no picture editing software, scanning software, etc. They are usually really cheap bloated software suits that don't compare to some of the more mainstream office products.
Nov 09, 2009 | Samsung SCX-4300 Monochrome Laser...
I cant find my cd to download my 5610 printer
Click the link below or copy the link below and paste in your browser,download the printer driver for the operating system you use on your machine.
http://www.siliconguide.com/drivers/device/874/
Hope it helps !
Thanks
Oct 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon mp240
Go to the canon site and download the xp drivers, remove the driver
and software, clean your registry, and reinstall the software and driver.
http://www.usa.canon.com/home
Pretty good registry cleaner for free,,
http://www.ccleaner.com/download
Apr 08, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Scanner
Download and install full software and driver package for your machine from brothers web site, it sounds like you have installed the print drivers but not the scanning software.
Oct 27, 2007 | Brother MFC-5440CN All-In-One InkJet...
Lexmark X1150 Will not scan or copy
If you are using windows xp home or pro and your scanner will not work and is making a clicking noise when you try to scan. this patch will fix the problem.
Just click on the link and download the patch.
PR1 ALL X1100 EA
Oct 15, 2007 | Lexmark X1150 All-In-One InkJet Printer
123 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
