Question about Danby DCD5505W Electric Dryer
Where can I buy the dryer belt?
I have been looking and can't seem to find the dryer belt. The repairman I called also couldn't find it. Help !!!
  • pjberard Oct 20, 2008
    Same issue, we cannot find a replacement belt.
Appliance Parts 15 Industrial Park Road Albany NY 12206 PH 888-603-1168
Posted on Jun 08, 2009
I bought my dryer belt dirrectly from Danby. They first gave me the name of a company to get it from, when I called them, I was told they no longer handled Danby. So I called Danby back, the woman I talked with was very helpful. She ordered the belt and sent instructions on how to change the belt out myself, and said if I had any problems with the installation, give them a call. It took me about two and a half hourse to replace the belt. But if I had to do it again I think I could do it in 30 to 45 min. By the way I'm a 60yr old woman.
Posted on Jun 05, 2009
  • 20 Answers
Try at marcone.com
Posted on May 23, 2010
We found one from a place called Reliable Parts (800) 666-0313 They're basically in the Western US.
Posted on Feb 06, 2009
Replace drive belt
This is a pretty simple DIY repair that can save you a bunch of money by not calling a repairman to do it for you. Here's a comprehensive how-to video showing how it is done on a Whirlpool dryer.
Your brand dryer may be different - but should have a very similar belt replacement procedure. If you'd rather see a video for your brand / model, have a look here for available belt replacement videos for other brands.
I hope this helps & good luck. Please rate my reply. Thank you.
Apr 16, 2011 | Dryers
Dryer belt broken
Your brand dryer may be different - but should have a very similar belt replacement procedure. If you'd rather see a video for your brand / model, have a look here for available belt replacement videos.
Apr 15, 2011 | Dryers
My 13 year old Maytag Dryer rumbles to a start when you turn it on and rumbles to a stop. Sounds like the belt is slipping to me. Should I contact a repairman to replace it?
I would check the drum rollers and glides first, the other cause may be the idler assembly which is next to the motor, it keeps tension on the belt. Since you will have it apart you can check the belt for cracks and wear, if it looks good then I would not replace it. eBay is a cheap place to find dryer parts, here is a website on the rollers/glide you can go to the virtual repairman and it will help. I think it is a good site to troubleshoot just about anything you may have problems with, Good Luck Tim.
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dec 18, 2010 | Maytag PYE4557A Dryer
My whirlpool AWZ2303 only seems to be blowing cold
If your not getting heat from the machine its probably due to a faulty heating element. You can get the part at an appliance parts shop by bringing them the model number or you can call in a pro repairman to have a look and replace it. Do it yourself is cheaper by far but can be difficult on newer machines like this one.
Dec 11, 2009 | Whirlpool Dryers
My dryer won't turn on
Make sure that the problem is not a broken belt, or a belt that has slipped off of the motor pulley or idle arm pulley.
Look to see if the motor is running first, sometimes you cannot hear the motor running but it is.
Also you can check your breakers to see if one is kicked out.
This problem can also be caused by a faulty start switch.
If this is not the problem than it may be time to call the repairman
Sep 26, 2009 | Kenmore Dryers
I hear the motor running, but the dryer does not spin.What should i do?
your belt has been either stretched and no longer fits snugly around the drum enough to turn it or its snapped all together
in all honesty unless you've done it before i'd call a repairman, for two reasons its a 220 appliance and taking a newer drier apart means lots of little skrews and cut fingers
Jun 28, 2009 | Kenmore 63942 Dryer
Drum will not rotate in LEW0050p Dryer
hello is the door making the switch if thats ok check wires see if any are loose if thats ok .at the bottom of the machine next to the motor theres a part callled a capacitor its got 2 wires coming off it this can stop the dryer rotating i hope this help
Jan 28, 2009 | Whirlpool LEW0050P Electric Dryer
Gas dryer problem
I am getting water in my vent hose. What could cause this.
Dec 13, 2008 | Roper RGX4634KQ Gas Dryer
GE Spacemaker stackable washer/dryer
The front cover come off by removing two philips screws on the bottom of the panel. That will expose all the operating parts of the washer.
Sep 17, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
You should go in through the front. Use a flashlight and look between the front panel and the top panel. You should see some clips there. Stick a flathead screwdriver into the clips to pop the top up and then remove the front. The front may be held in by screws, but since I don't know which model you have, look inside once you pop the top and see if there are screws. Then you should be able to remove the front panel and see the belt.
Mar 26, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Danby DCD5505W Electric Dryer Logo
2,782 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
