Question about Microsoft Xbox 360 Console
Red light the red light is on mt console around the power button
    New Friend:
  • 161 Answers
Ahhh...the red ring of death....ur 360 is fried n needs to be sent back....microsoft will repair for free.....its theyre fault
Posted on Sep 30, 2008
Blinken red light around the power button
hello sir
Solving Your Red Light Flashing:
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shadow
Jul 26, 2010 | Microsoft Xbox 360 Console
Trying to turn xbox on and getting blinking red ring around power button
If you are having three red lights flashing around the power button with upper right corner not flashing, it means that your Xbox 360 is having a general hardware failure. This is caused by the internal components of the console experiencing a malfunction. You can contact Microsoft Xbox Support for it to be repaired.
May 10, 2010 | Microsoft Xbox 360 Console
When i turn my xbox 360 on it starts running hard then the controller lights on the device start flashing red.
Four lights around the power button flash red on your Xbox 360 console. Four flashing lights indicates that the console does not detect an audio/video (AV) cable.
Note Four flashing red lights will not appear on consoles that have both an AV port and an HDMI port.
Solution
http://support.microsoft.com/kb/906652
Mar 24, 2010 | Microsoft Xbox 360 Console
I HAVE 4 RED RING WHEN I TURN ON MY XBOX
Solution
Mar 23, 2010 | Microsoft Xbox 360 Console
Flashing red light
if its three of one red light, its broken and youll need to send it to microsoft for repair
Dec 30, 2009 | Microsoft Xbox 360 Console
My xbox360 has a red circle instead of a green circle theirfore will not work what can this be
Three flashing red lights around the Xbox 360 power button (nicknamed the "Red Ring of Death"), represent an internal problem that requires service. Warning signs may include freeze-ups, graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, and sound errors, and the console only responds to pressing the power button to turn it off.
This error code is usually caused by failure of one or more hardware components, although it can indicate that the console is not receiving enough power from the power supply, which can either be due to a faulty power supply or if the power supply cable is not fully inserted into the console.
Distinct from the General Hardware Failure is a similar-looking error warning where four red lights appear, in which case the console does not detect an AV cable is plugged in. The four lights can sometimes also be seen when power surges or very brief power outages occur while the console is running, in which the console needs to be unplugged and plugged back in again to reset the error. Two red lights appear when the system is overheated.
Oct 06, 2009 | Microsoft Xbox 360 Console
Xbox 360
how many red lights are there?
Jun 26, 2008 | Microsoft Xbox 360 Console
Red light flashes around the power button on the console
Four red lights- Your cables connecting the 360 to the power or the tv are loose.
Three red lights- console is broken, send it in for repair
one red light-console is broken, send it in for repair.
Apr 29, 2008 | Video Game Consoles & Games
Red light on startup
This happened to me 2 or 3 times.I checked the power supply and found that it was loose(the one in the back of the actual 360 console)when I pushed it in properly,is worked fine,i have not got this problem at all since then.So just make sure the power supply is properly connected.
Jan 17, 2008 | Microsoft Xbox 360 Console
Red light on my xbox 360
Turn console of, hold sync button down wich is the small white button next memory card slots, while holding turn on console and wait till it boots. If this does not work go to system blade, select memory, press y on the HD symbol, press xx left bumper right bumper xx, select yes. This will restart your console from scratch though all profiles and saved data will be lost, but it will clear any corupt data.
Sep 16, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
