How do i completly do a system recovery that makes my e-machine back to new?
  • jknight2008 Dec 31, 2008
    i have a w3503 the hard drive was erased completely.
    No there was no system restore cd with the purchase.
    How can I reconfigure BIOS to accept a new operating system?
    Guru:
  • 558 Answers
Just reboot your PC by Pressing F8, this will brings you the menu for selection of some choices.
Move up and down arrow key to Load window to Factory setting.
This will load window to new one without any extra Application installed.
Regards
Ellin
Posted on Sep 29, 2008
  • Puneet Jain
    Puneet Jain Oct 18, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
    Master:
  • 788 Answers
It should have come with a restore CD or DVD. Boot to it and follow the instructions. Keep in mind that you will lose all the information you have saved on the computer.
How to go back to factory settings
All data will be erased on your hard drive if you proceed. Make sure that the power wont be interrupted during this process. Do not switch off or restart your computer either.
-Shut the computer down completely
-hold the 0 (zero) key down and at the same time press the power on button release the power when the machine turns on
-when the computer starts beeping release the 0 key
-when the prompt comes up choose YES to continue with system recovery
-Select recover of factory default software and click NEXT
-Click Next again to start recovery
Hope this helps!
Apr 14, 2011 | Toshiba Satellite Pro L300 Notebook
My pc runs fine in safe mode but freezes in normal mode why?
It is an issue with some 3rd party softwares.
Try doing a complete system recovery after backing up the datas.
For doing this, power on the netbook and keep tapping Alt+F10.
That will take u in to the recovery mode.
Select complete system recovery.
This process will take around 30 to 45 min and make sure u plug in the AC adapter.
Dec 07, 2010 | Acer Aspire SA80 (ASA80UC4603) PC Desktop
Just formated my computer and was all gud untill it asked for the product key. i tried the one on my pc but it didnt work. whould like to get some keys that work plz
the one on your pc should be a microsoft coa therefore it should work make sure everything you type in is done correctly with the space - between the first set of numbers if you cant get your keyboard to work try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts
hope this helps
Nov 30, 2010 | Microsoft Windows XP Professional With...
Hi there .I would like to help my friend use the recovery partition on her compaq presario c700 laptop to either use her recovery dvds or simply to reformat(restore the computer to original factory...
The recovery partition is usually hidden and cannot be seen in the Windows operating system with out adjustments to the way the files are displayed.
Most likely they are present and you can use the following methods to access the HP Recovery Manager utility.
PLEASE NOTE: Using the recovery utility will result in a complete loss of data. Please backup any data you wish to preserve before running the HP Recovery Manager as all data such as photos, documents, music and favorites will be completely erased after the recovery is complete.
There are 3 ways to recover an HP/Compaq PC using the HP Recovery Manager.
Method 1 involves booting into the Windows Operating System, and starting the Recovery Manager from the HP utilities.
Method 2 involves pressing the "F11" key during initial startup to access the Recovery Manager from the recovery partition.
Method 3 involves using personalized recovery disks created by the user when the machine was new or a replacement set of recovery disk obtained form HP.
Follow the on screen prompts to complete the process. As the machine is has been set back to how it was from the factory, make sure to apply all Windows updates as there will be approximately 3 years worth, including 2 service packs, many critical updates and driver updates.
More on this subject here at HP's support site http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00809678
Feb 24, 2010 | Compaq Computers & Internet
Need to reload windows xp on Emachines PC
Yes all you have to do is.........
Turn off the Computer
Turn back on and Press F11 repeatedly when the message "Press F11 to start recovery" is displayed.
The recovery will load and display a menu of options:
Full System Restore (with Backup): This options will move all Hard Disk contents to the "c:\My Backup" directory and install a new copy of Windows. This option preserves your existing data files, however all applications and settings will need to be reinstalled. This option requires 4GB of free Hard Disk space for the new OS.
Alway suggest backing up your data before you do any recovery
Mar 19, 2009 | E-Machines eMachines Desktop PC
Emachine t3104
For doing a system recovery on E-machine you have to press F11 number of times at the very first boot screen then follow the procedure, and it will restore your computer back to the factory settings.
This option is available in new computers only. (2-3 years old)
Jan 12, 2009 | E-Machines (T3104) PC Desktop
Sytem recovery not fully completed
Do you have the OEM Windows CD with Key Code numbers? If yes and there is nothing on the hard drive you want to save you could try a clean install. Go to set-up and make CD-ROM drive the first boot device and install a new OS. Sometimes with Windows this is the easiest thing to do. I see this recovery/restore stuff leaves a lot to be desired. In other words, it doesn't seem to work half the time.
Jan 06, 2009 | E-Machines eMachines Desktop PC
To make recovery partition for vista
If that's a brand new model damroo, the recovery cd should be a software that you can click on the desktop, it should say something like HP PC System Recovery or something similar. For a complete guide, try checking this out. It should be similar in making recovery cd on XP/Vista.
Hope this helps.
Oct 03, 2008 | Microsoft Windows Vista Ultimate Edition
I recently formated my compaq compter now windows wont start . it goes to the compaq logo page and gives options to boot menu , setup , system recovery but does not let me do anything ? any ideas to what i...
Have you upgraded your system in anyway since first purchasing it? I had this same problem after formatting because I had installed a new graphics card and more RAM on my compaq machine. All I had to do was remove the additions before reformatting.
May 01, 2008 | Computers & Internet
Restoration disk
Restoring the PC to its original state by doing a system recovery ! Just make sure you back up your important data if you can before doing the system recovery !
1. Plug in the AC adapter.
2. Turn the system on
3. Immediately, press ALT on the keyboard and start tapping F10.
Continue holding ALT and tapping F10 as the unit boots up.
4. A screen stating "Starting Acer Erecovery" should appear.
(Release ALT and stop tapping F10 at this point)
5. There will be 4 options:
1. Restore system to factory default
2. Restore system from user backup
3. Restore system from cd/dvd
4. Exit
1. Enter the password created when eRecovery was first started.
2. Read the on-screen warning and choose Yes.
3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
1. If recovery cd/dvd's were created, they can be used to restore the system.
2. Insert disc 1 and follow the prompts.
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
