Question about Brother MFC-7820N Laser Printer
Scanner leaves three vertical lines on scanned page
When I scan a page there are three vertical lines on every page that appear in the scan. Help!!!
Regards,
Gary
  • chrisco35 Oct 16, 2008
    what do you correct this issue?
    Problem Solver:
  • 5 Answers
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Posted on Jan 07, 2010
  • Yi-Ling Lin Sep 24, 2013
    Hi, I found the balck line with a Scan operation when I choose the "auto" scan source" in my Dell 2335. As you mentioned, it could be a fault/dirty/obstructed LED module. How can I do for the issue? Thanks.
    Master:
  • 788 Answers
You need to clean the glass.
Posted on Sep 29, 2008
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
I have a big black line down the middle of my scans
If dirt sticks to the scan module, it will be scanned continuously and appear as a line in the output. Clean the glass with Isopropyl Alcohol. Dont use any other solvent.
S. Mohan, India
Mar 12, 2013 | Canon DR-5010C Scanner
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
Brother MFC-7820N Printer--vertical lines
You need to clean the scanner glass. Also known as the strip glass. It is a 1 inch wide strip of glass that runs from the front to the back. Your documents pass over this glass when they are scanned. Some of the wax crayon probably smeared off onto the glass and now when you scan the scanner sees these marks as stationary and thus records them as solid lines. Just look into the scanner section where your documents are fed in or depending on model, some are just to the left of the large original glass.
Good Luck and thank you for using Fixya.
Feb 25, 2010 | Brother MFC-7820N Printer
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Mustek Scan Express A3 USB Scanner
I've had a similar problem with the streaks, lines and color bleeds appearing in the scan. Try uninstalling the all software and drivers for the scanner and reinstall. Worked for me. Have had to do this a couple of times since I've owned the scanner... about three to four years now.
Jan 25, 2009 | Mustek A3 USB Flatbed Scanner
Vertical lines in scanned documents
Scan glass has muck on it, needs to be perfectly clear, it is just in where you feed originals.
Nov 21, 2007 | HP LaserJet 3050 All-In-One Printer
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Scanner inserts vertical line on some documents
Clean the glass with IsoPropyl Alcohol. Dont use any other solvent. A speck of dust stuck to the glass can give a continuous line in the output
S. Mohan
Sep 29, 2006 | Canon DR-1210C Scanner
Brother MFC-7820N Laser Printer Logo
1,968 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
