Question about Panasonic KX-T7730 Corded Phone
Picking up a call
HI! I used to be able to pick up a call from a phone connected to the Main Unit, by dialing "40". Now it must have been deactivated somehow, because everytime I try to pick up a call by dialing the same code "40", it gives me a busy tone, and the Main Unit keeps ringing. Do you know how I can fix this? Thnx
  • zhunaula2003 Sep 29, 2008
    I FORGOT DE CODE OF MY TELEFONE, ITS DODE IS NO.KX-TSC10LXW
  • Panasonic Master
  • 2,460 Answers
@AlexaF
A couple of things to try. First, walk up to the phone that's ringing and dial 720# on the intercom. They may have set Call Pickup Deny (by dialing 721) and this will clear it.
If that doesn't work, you may have fallen out of the pickup group. You can test this by using the Directed Call Pickup code which is 4 + the ringing extension number.
If that works, but 40 doesn't, there's some programming(system prog 600) that needs to be examined. By default though, each phone is in pickup group 1.
Carl
Posted on Sep 29, 2008
Etw 16d 1a
From one of the two main phones, typically used for the receptionist, without picking up the handset, dial Feature, 9, #, to get into time mode. Dial the hour, cursor jumps to minutes, dial the minutes, cursor might jump to seconds, then press Feature to write and exit. If you're also doing the date, after the seconds press Hold, goes into day/month/year, then press Feature to write and exit.
Apr 15, 2014 | NEC Lands Phones
How to pick up a internal call from colleague extension?
Depending on the system the phone is connected to, you can dial 40 on the intercom or 4+1xx (the intercomed extension) to pick up the call.
40 will pick up anything ringing in your group, so if you want to be sure it's only going to answer your colleague's call, use the 41xx code.
If the code doesn't work, check out your user's guide for directed call pickup.
Carl
Dec 31, 2012 | Panasonic KX-T7730 Corded Phone
Avaya / Lucent MLS-12D Partner MLS12D Display Phone - BLACK: when A user picking the Avaya phone up, user don't...
get more lines.
Or check Auto line select.
From ext 10 or 11:
press feature 00
press left intercom twice
press right intercom once
enter extension number
press **
then press the lines in the order you want them picked up (line 5, 4, 3, 2, 1 then the intercom )
press**
press feature 00 to exit programming.
When the extension picks, it will pick up line 5. If 5 is busy, it will pick up line 4 , etc....
May 16, 2010 | AT&T Lucent MLS-12D Phone
How do i forward a call to a cell phone?
I believe your landline carrier just needs to have the capability of call forwarding (ie we utilize Verizon for our business). We also use the call forward feature by: picking up line, (hear dial tone) dial *72 [ then phone number you want calls to forward to, even a cell]. To discontinue: pick up line (hear dial tone) dial *73
Mar 02, 2010 | NEC Dterm DTP 16D-1 Corded Phone
Programming Auto Dial Number
Yep. Those are speed dial numbers. They are programmed from ext 101 or the main phone. Without picking up the handset, press PROG **1234 and dial 001 and ENTER. Dial your 3 digit speed dial number If there is something there, it will be displayed. A speed dial number is stored with the trunk access code in it (usually 9) so if you're putting in a new number, include the "9" plus the number exactly the way you dial it. Dial your new number with the access code and press ENTER.
Number changed :-)
You can keep putting in a whole boatload of new numbers with this procedure.
Carl
Mar 16, 2009 | Panasonic KX-T7633 Corded Phone
Someone is picking up on my line
Get A New One.Someone Hacking Your Phone Line
Jan 24, 2009 | Panasonic KX-TG1033S Cordless Phone
KX-T7730 Picking up Problem
You are on the right track but the extension number is not " 0 ". There is an extension number associated with the operator phone just as your phone may be " Extension 101". If you have a display phone have the operator call you and look at your display for her/his extension number then when their phone is ringing, pick up your handset, dial 4 plus the extension number of the operator. Let me know how it works out. .....Mitelmike
Nov 18, 2008 | Panasonic KX-TA308 Phone
Fax picking up over phone number
Do you have an Answering Machine?
If yes then the Rings to answer on the Fax should be more than the rings to answer on the Answering machine.
Press the Setup button on the Printer and then go to Basic Fax setup and you will get the Rings to Answer option there.
May 25, 2008 | HP Officejet 5610 All-In-One InkJet...
INTELLIFAX 2820 NO FAXES COMING THROUGH
Oops, I disconnected from the chat with you after I said I would stay connected. If you have any other questions, feel free to ask them here. Just for our knowledge base, in case anyone else has this problem - it turned out to be a short in the phone line. When picking up the handset connected to the fax machine, there was no dial tone. When connecting the fax machine to another phone line, the dial tone returned. After swapping out the phone cord between the wall and the fax machine to be sure that wasn't the problem, Jriedel is now talking to the phone company about it.
Sep 12, 2007 | Brother IntelliFax-2820 Laser Fax
Panasonic KX-T7730 Corded Phone Logo
247 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
