Question about HHB CDR850 CD Recorder
Hhb cd recorder
When i start burning a cd on problem, it when i try to finalize it tells me that i still have a blank disc place
  • 27 Answers
At the time of burning to avoid this problem select multisession option in nero:
Posted on Sep 30, 2008
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
Need remote for my hhb butnit plus
Either contact hhb or look on E bay. Universal remotes usually do not have enough of the functions required to finalize discs and such.
Dec 26, 2012 | HHB BurnIt CDR830 CD Recorder
DURNING FINALIZE MODE IT STOPPED WITH1:30 LEFT--- THEN I TURNED IT OFF AND TRIED AGAIN TO FINALIZE AND IT CAME UP WITH A READING OF---REPAIR--
That's a normal response to an interrupted Finalization.
http://www.retrevo.com/support/HHB-CDR830-CD-Players-manual/id/3875ci874/t/2/
The recorder was switched off/unplugged after recording without ejecting the disc. The recorder could not write essential recording information onto the disc.
While REPAIR is displayed, the recorder automatically examines the recorded area of the disc and updates the track numbers and recording time data. This process takes about 40 minutes for a fully recorded disc. Finalization or further recording is possible once the REPAIR message disappears.
Jan 23, 2011 | HHB BurnIt CDR830 CD Recorder
We ejected the cd accidentaly without finalizing from the HHB CDR850. we REALLY need this audio. what can we do?
sounds interesting
did the power fail during recording?
have you tried putting the cd back in the machine?
you should be able to finalise it as long as the PMA completed
the disc wont come out normally untill the PMA rec message finishes.
i have this machine myself.
there is a mode that will scan a disc if the PMA is missing
if power was turned off during recording it usually enters a "REPAIR" mode when turned on again.
this takes 40 mins to complete but the audio can be finalised as normal after it completes.
try putting the disc back in and see if it can be repaired or finalised
darren
Nov 14, 2010 | HHB CDR850 CD Recorder
Hi there, when recording analogue from mixer to HHB Burner 830 the blank cd does not read properly, and records blank even thou the connections are in the right ins and out (phono to phono) And the input...
I can only assume that it's not changing the analogue signal into a format suitable for transferring to a CD. Check the recording settings. Make certain the signal is being converted to say a WAV format or MP3 etc.
May 01, 2017 | HHB BurnIt CDR830 CD Recorder
AFTER recording is made Tried to finalize and it says repair... what is causing this .
The CDR lost track of the information on the disc. This most often happens when the unit is powered off before the disc was ejected. Give the unit about 40 minutes to go through the disc contents and locate the tracks. When the Repair message goes away, then you can finalize the disc.
I hope this helps
Sep 24, 2010 | HHB BurnIt CDR830 CD Recorder
My Ge Force will burn audio but not DVD.I have tried with Ashampoo,Record Now and Express Burner.The burning programme tells me there is no disc in drive
Hi Brian.
I think you are a little confused.
Your GeForce FX 5500 is a graphics card
All this does is allow you to see your desktop on a monitor and play some games.
For burning discs you need a cd/dvd burner. This is a cd/dvd drive that you can use to read and write cd's and dvd's
You say that your program is telling you that there is no disc in the drive. (Your CD/DVD burner drive)
You can burn audio discs so this tells me you know that much and you have blank cd's so my two things I need to tell you are these..
1. To make a DVD or Burn a DVD you need a BLANK DVD disc in your burning drive. Maybe you have mistakenly placed a CD in the drive instead?
2. Your Burner drive may not burn DVD's only CD's?
Check on the door to the drive that opens to allow you to place discs into it. It should say something like DVD multi recorder or Compact Disc re-writeable. If it does not say DVD on it anywhere your drive is not capable of burning DVD movies and therefore you will need to purchase another burner.
I hope this helps?
Sep 08, 2010 | Nvidia GeForce FX 5500 Video Card Graphic...
Can't finalize after recording, disc error
So are they always CD-RW?
I have a Pioneer PD509 which is a spittin' image of the HHB CDR830 but tied down to use CD-Audio discs only.
My experiece with Rewriteable Media has been that they don't hold up to multiple uses. I used them to make quick 'n' dirty dubs of cassette audio then worked it into a polished copy with proper track marks and sweetening later for copy over to a CD-RA. After a few passes I'd start getting audible problems when copying off the -RW's, so I routinely just use them about 5 times. With two DVD players and a Blu-Ray I sometimes get through the errors on one of them for one final digital copy and then I can them.
BTW: you may want to try the failing disc in a DVD player. Mine will play through an unfinalized CD but can't cue up to anything. So if the recording is vital you might retrieve it that way. Just remember to pause the Recorder at the end of the last cut you want because the DVD will just crash right into the old data without changing track numbers or any warning.
Mar 04, 2010 | HHB BurnIt CDR830 CD Recorder
Cannot use the finalize function anymore
they wear out have it serviced and cleaned
Nov 05, 2009 | HHB BurnIt CDR830 CD Recorder
Does not reconize blank CDs
this is cd reading problem so open ur cpu and see the bus connection in between motherboard to cd drive....
and replace the bus.....
Jun 02, 2008 | HHB CDR850 CD Recorder
HHB CDR850 CD Recorder Logo
237 people viewed this question
Top HHB Audio Players & Recorders Experts
John
John
darren dillon
Level 1 Expert
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
