SOURCE: Is buying this Hp Compaq 6910p Battery a wise decision?
I have bought a couple of batteries from them before. They work just make sure that the voltage of the battery. (10.8v) matches the voltage on your battery. Also make sure that the mah 6600mah is greater or the same as the battery that you have. The mah is the mili ampers per hour (in other words the fuel) the bigger the mah the longer your battery will run. I also find ebay a great place to buy hp batterys from. Just make sure that they are oem hp and not a generic knock off and you will be fine and use the same rules from above. and also make sure they will fit your model number. I hope this helps
thanks
Steven.
