Question about Sharp Aquos LC-32D40U Television
Picture Blacks Out, Sounds Stays On
My Aquos LC-32D4OU TV works fine until suddenly the picture blacks out while the sound continues to play. Sometimes the problem is solved by turning the TV on or off or disconnecting it from the power source for several minutes. On the internet, I note that others have this problem and some have solved it by replacing the screws in the back of the TV control panel. Which screws I do not know and I'm wondering if Sharp should fix this free of charge since it seems to be a defect with their product (the tv is no longer on warranty). Can you help?
  • 2 more comments
  • lthomasva Oct 06, 2008
    LC-40C32U Picture blacks out and the sound stays on. Turning tv off and on brings picture back for 30 minutes or so. Need pernment fix.
  • mariusgabi Oct 15, 2008
    I have exactly the same problem.
    Please send me a notification when solution found
  • kmhav52 Oct 16, 2008
    The TV repairman changed the screws in the back of the TV. He said the original model screws do not hinge in properly, get loose, and therefore causes the blackout program. This was done at no cost after I complained to the main office even though the TV is not covered under warranty. It's now 2 weeks and the TV works perfectly with no problems whatsoever.
    If you are having the same problem (it sounds fairly common), insist that it is fixed for free. I'm very happy that I did.
    kmhav52
  • Anonymous Nov 13, 2008
    Where there is smoke there is fire and Sharp is well aware of this defective circuit boards installed in our LC-32D40U TV's.
    I watched the Texas Tech Oklahoma State game great picture as usual. Sunday morning turned on the TV and no picture. The sound works fine if you get lucky enough to find the the right settings. At this point I can't see what my settings are and of course I had to press every button on the remote and the TV at least a dozen times each. For me that explains why I thought I had a multitude of malfunctions. I will be on Sharp like a chicken on a June bug as soon as they arrive at for work in the morning.
Have sme problem as kmhavs2. Called Sharp 800 number.
Talked to several people at Sharp. They set up repair service
at no charge. Repairman supposed to come Oct 21.
Posted on Oct 16, 2008
I spoke to several representatives from Sharp and ultimately they are sending a repair person to take care of this problem at no charge. They realize that this is a problem enountered by several people who own this TV. Hopefully, the repair service will be here in the next day or two.
Posted on Sep 30, 2008
Sharp lc-32d4ou screen blacks out
I do have a work around that I have used on this model for the past3 years. if the sceen goes black. Turn off the tv. Grab the upper left and right hand corners of the tv with your hands. Flex the tv slightly back and forth. then turn it back on. my will usually run for hours after I do this. I do this 4 times a week. I works 100% if the time for me. Sharp lost a customer. good luck.
Aug 31, 2010 | Sharp Aquos LC-32D40U Television
Picture goes off..sound stays on
Make sure the cooling to the TV is not blocked. It is on all the time even when off. Some of the spply cucuits remain on continuously. try uplugging the unit. Let it cool. If it is an older TV the back lighting may be dieing, then it is Tech. time
Mar 25, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Sharpe Aquos TV screen stays black even when switched on!
Call up Sharp, if you are part of the AQUOS Advantage Program, you get FREE in home service along with the repairs for it.
They'll give you a case number, set you up with a technician and BAM!
I called on a Wednesday and got an appt for that Saturday for the technician to come to my house.
I doubted Sharp alot less after that.
Aug 28, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Picture but no sound
main pcb needs to be cleaned were audio ic is. there is black gunk
Jun 01, 2009 | Sharp AQUOS LC-32D44U 32 in. LCD TV
Sharp Aquos LC-32D41U pictures problem
I have had exactly the same problem. Sounds daft but by not using the remote, and only using the power on/off switch on the TV itself, it is working perfectly...no idea why
Use the remore for changing programmes etc but not for on/off
Try it anyway because I know how annoying this is
Mar 29, 2009 | Sharp LC-32D41U 32 in. LCD Television
Sharp Aquos LC-32D4OU
Comment by Guest, posted on Oct 25, 2008My Aquos has the same problem. I'm not sure how I discovered this, but when I lean the TV forward and hit the power button it will turn on every time. If the screen blacks out and I don't lean it forward when I hit the power button, the screen will just remain blank. It is very weird, but at least repeatable.
- Thank you, Guest. That did it. It definitely seems to be a problem with the TV. Tilting it and hitting the power button helped me get the video back.
Jun 05, 2008 | Sharp Aquos LC-32D40U Television
TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Mar 31, 2006 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Televison & Video Logo
322 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
