Question about AudioBahn ABASS120P Car Mid-Range Speaker
Audiobahn abass120p powered sub wiring harness plug
I bought a used audiobahn powered sub and need to know what wires go where so i can make a plug for it , thanks
3 Suggested Answers
  • 7 Answers
SOURCE: Wiring a Kenwood KSC-WD250 Subwoofer
7e83231.jpgi had the same problem Here is the diagram i used from someone else on fixya.  Thank you.
Posted on Jul 21, 2008
  • 4 Answers
SOURCE: Audiobahn ATB8AT
I had the same problem. I looked everywhere and could not find the right type of harness. You may be able to find a similar sized harness at a local electronics store that you could, possibly, slightly tamper to make work, but the easiest thing i found to do was I took the amp out of the box (it's only the ciruit board) and very carefully soldered the ground, remote, and power wires directly onto the pins on the plug. I cut the wires I soldered on down to about 4 inches and then used wire nuts to attach the actual wires coming from my HU, battery, and ground.
Posted on Nov 19, 2008
uge44
  • 226 Answers
SOURCE: i dont know which wires
I used to have exactly the same subwoofer. It has dual voice coils which are driven independently.
Hope the diagrams help out. Just make sure you know how many ohms your amp is.
Wiring Option #1
Wiring Option #2
Posted on Nov 20, 2008
How do you wire an audiobahn awis15j
I need to know how to wire my asi 15" subwoffers to my amp because theres 8 places to put wires on each sub.
Feb 27, 2012 | AudioBahn Car Audio & Video
No sound from sub
simply give it a 2 wire signal and you should hear something! if not then depress the cone lightly back and forth, if you hear alot of scratching/scraping sounds, prognosis in not good.
Sep 15, 2009 | AudioBahn AWES12P Car Subwoofer
Need wiring diagram for sub
u should have two pos, an two neg. on the back of the sub run a wire from one pos to the other same with neg. now just run a pos an neg from the box to one side of the sub u should have one side with two wires runing to the pos. an neg. if u need more help let me know bertman285@hotmail.com
Apr 25, 2009 | Car Audio & Video
I dont know which wires go where on the back of my sub woofer. its an audiobahn aw1251t woofer, 400 watts
Wiring Option #1
Wiring Option #2
Nov 20, 2008 | AudioBahn Car Audio & Video
Audiobahn powered subwoofer
yep, they dont make audiobahn any more i think they still make other subs to one of them is DUB subs, ebay is the best place for me to find audiobahn, and for parts...
Jul 24, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Audiobahn sub settup
audiobahn.com has a tech support with diagrams on thier website check it out
Jun 03, 2008 | AudioBahn AW121T Car Subwoofer
Wiring subs
audiobahn.com can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
Audiobahn ATB8AT
try radioshack, walmart, or try ebay
Jan 06, 2008 | Audiovox BA200 Car Subwoofer
Audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Dec 20, 2007 | Car Audio & Video
AudioBahn ABASS120P Car Mid-Range Speaker Logo
233 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
matthew walsh
Level 1 Expert
Iron
Iron
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
