Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Problem with light on unit
Light bulb flickers on right side of unit all the time
    An expert whose answer gotĀ voted for 100 times.
  • 98 Answers
Try unplugging the unit, unscrewing the bulb and with a small scrapping tool (small flat screwdriver) scrap the bottom contact and the contact on the threads. Bend the contact on the threads a little too make better contact with the bulb. Screw the bulb the bulb in completely.
Posted on Jan 08, 2009
Left indicator light flicker too fast
If the right side works properly, switch all indicator bulbs one at a time. test with each bulb change. Untill you find the one that makes it flash at the rite timing. I had a bad rear bulb. The brake filiment was laying on the tail light filiment. This made the blinker timing bad.
Jan 26, 2014 | Hyundai Tucson Cars & Trucks
Brake Lights Dull or Flickering - All Cars
Dull or Dim Brake Light Repair: If your car has a dull or dim brake light it is dangerous to you and other drivers. A dim brake light is a mystery to most people because the bulb is working, just not correctly. First confirm a new and correct brake light bulb has been installed. Next, turn the ignition key to the "on" position and have a helper depress the brake pedal. With the bulb installed touch a grounded test light to the outer bulb holder ring. If the bulb brightness changes the bulb socket ground has high resistance and needs to be repaired or replaced.
Flickering Brake Light Bulb Repair: A flickering brake light bulb can be very distracting and annoying. A brake light flickers because the power or ground is being obstructed momentarily. The most common cause for this condition is a loose fitting bulb socket. To check for this condition remove the brake light bulb in question, while a helper hold their foot on the brake pedal move the bulb around slightly in the socket. If the bulb flickers replace or repair the bulb socket as needed to regain proper brake light bulb operation. If the brake light bulb socket tests ok wiggle the brake light fuse and wiring at the brake light bulb socket, brake light switch and turn signal switch (American cars). If the brake light bulb flickers repair the component or wiring as needed.
Preferred Procedure: Always replace brake light bulbs with manufacturers recommend replacement bulbs. If you cannot find the correct replacement bulb part number consult an auto parts store for additional manufacturer information.
Common Problems
When brake light bulbs are replaced with the incorrect bulb causing no or dim brake light operation
If the brake lights stay on continuously it could mean the brake light switch has failed or an adjustment is needed.
on Dec 18, 2009 | Honda Civic Cars & Trucks
My son has a Handy Manny Flicker the Flashlight by Mattel. It appears that the bulb is burned out and I cannot seem to find how to replace it. Please Help!!!
The light bulb is soldiered in. However, if you unsolder the bulb you can order one off the internet and soldier it in. Pay close attention to which wire is soldiered to the bottom and which wire is soldiered more on the side of the light bulb. This is the only way to replace this light bulb.
Mar 23, 2011 | Mattel Handy manny fix it right motorcycle...
Low beam on passenger side is out. My 2002 Acura TL Low Beam light starting flickering and now it doesn't work at all. It's on the passengers side and I've got some outrageous quotes on fixing it. Light...
Sounds like it is an HID light system on there, you can get after market bulbs MUCH cheaper then from the dealer. and with the bulb flickering first, then dying, it sounds like a bulb issue, not the ballast.
let me know where you live, i might be able to point you in the right direction.
Oct 29, 2010 | 2002 Acura 3.2TL
Light bulb flickers and strange sound
that is just a small problem..try check ur bulb..maybe its loose,tighten it back..then that strange sound maybe came from spark between the bulb and its connection..
Sep 18, 2009 | Whirlpool GS5SHAXN Side by Side...
Flickering light GE 48' side by side refrigerator
i had the same trouble .. in mine there is a plastic cover that slides off with some difficulty (slides toward the front) ... this exposes the light bulb which was simply loose ... its also possible to have a bad bulb but make sure you replace it with the same type and wattage ... observe how the plastic cover came off since its not obvious how it goes back on ..
Aug 05, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Lights Out
maybe the bulb is not compatible with a frigde itself. It is not like a convential house bulb that you can plug it on the socket and it will light up..
since these special light bulbs has low voltage.
if you want, you click this link below to purchase the right bulb.
hope this will help yah!! Goodluck!!
Feb 05, 2008 | Whirlpool GS6SHEXNL Side by Side...
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
56 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
