Question about Dryers
Maytag Neptune Front Load Dryer - No Heat (MDE5500AYW)
There is no heat on my electric dryer. I am not good and scared of electricity, but also have been out of work since June and am single mom 2 kids (clothes keep coming) and must fix this myself. Can anyone guide me through what to check. It runs fine, but is not in the least bit warm. I have changed all the button settings, checked the breaker, cleaned the filter - vancumed as far as i could in the exhaust tube. Help!
  • 3 more comments
  • CarolynHS Sep 29, 2008
    Thanks - I will try and locate the airing diagram but do not see it the manuals that came with it. Any idea where i can get it? I'll post back when I find it and borrow a multi-meter. Is the multi-ytester a sperate item i will need? Thanks! Carolyn
    I am dyered out for the day. i downloaded the manual and ran the diagnostics which came up empty. I will try and borrow a meter thing for tomorrow. Thanks for you help!!! I'll be back :)
  • CarolynHS Oct 02, 2008
    Hi DRcool - I have been unable to borrow a tester yet and hope to get back to looking today!! Thanks for checking - dyer still cool BOOO - Thanks ! Carolyn
    Got tied up on job stuff, and have been unable to borrow a tester yet. Hope to get back to it by the weekend - thanks for standing by :) Carolyn
  • Anonymous Dec 14, 2008
    no heat
  • 958 Answers
Hi carolyn,
if you can use a multi meter, then i can guide you which part to order. if you would have the wiring diagram of your unit then it is much better. plus basic tools to open your dryer. phillips screwdriver, 1/4 hexnut driver, and a multi-tester to test continuity.
90 percent of dryer not heating is the thermal cutoff switch. if you can test yours, then that would help you and save you a lot of $$$.
tnx 4 using fixya,
drcool
Posted on Sep 29, 2008
  • francis rivero Sep 29, 2008
    you can find the wiring diagram inside the switch panel.
    the multi tester is the same as the multi meter.
    tnx,
    drcool
  • francis rivero Oct 02, 2008
    hi carolyn,
    how's the dryer?..i hope it is already heating up. keep me posted please.
    wish you all the best,
    drcool
WHY DOES MY NEPTUNE MATAG DRYER MDE5500AYW NOT HEAT ...AND WHERE ARE THE THERMAL SWITCH, HI LIMIT THERMOSTAT, AND HEATING ELEMENT?
All those parts are in the bottom front. TURN off the power! then open the front door and remove the 4 screw's, 2 on the hindges and 2 on the other side. Then you can close the door, and pull from the top edges of the front panel(sometimes you need a thin screw driver to free the front) the front panel will tilt forward and then you can lift it off. You will need a Ohm meter to check those parts for continuity. Make sure you remove the wires from the part you are testing.
Sep 30, 2014 | Maytag Neptune MDE5500AY Electric Dryer
Dryer running fine but just stopped heating. lint traps all clean.Maytag Neptune MDE5500AYW. HAVE THE DOOR AND FRONT PANEL OFF ALL ELEMENTS LOOK CLEAN AND ATTATCHED. No problem with home power...
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 23, 2011 | Maytag MDE5500AYW Electric Dryer
Have a neptune front load dryer heat does not work either does the lights on the control panel. heat works for a second but panel where time and
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Maytag Neptune MDE6700A Electric Dryer
I need to locate the heating element in my Maytag MDE5500AYW Dryer. I had the front pulled off and could see the drum etc. But could not easily find the heating element and I am afraid to take off too much...
www.scribd.com/.../Maytag-Neptune-MAH3000AWW-Service-Manual
Please use these service manuals, above and below to help you locate your issue, inside these manuals are all diagrams etc.
www.servicematters.com/maytag_library/docs/16010061.pdf
Jun 21, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have a MAYTAG MDE5500AYW drier that spins but doesn't heat up. Any recomendations?
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
No heat in dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
98uit
Feb 05, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
Watt for dryer
Total 5500 watts for motor timer and heating element on an electric model. (estimated)
Jan 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My maytag will not run
My neptune dryer electric mde5500ayw will not start the button seemed too be struck, and how can i take the side panel off to check the fuses inside
Nov 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
885 people viewed this question
Top Dryers Experts
